    [Plugin] TIG-Fracture
    39 Posts 15 Posters 12.3k Views 15 Watching
      A Pro >= v8 Plugin to "Fracture" a Selected Solid Group/Component.
      Dialog to set number of 'Iterations' and the 'Size %', and a final 'Explode' option...
      Now available in the PluginStore http://sketchucation.com/pluginstore?pln=TIG_Fracture
      • jujuJ Offline
        juju
        "pics or it didn't happen"
          • jujuJ Offline
            juju
            thanks, as always, TIG delivers...
              driven
              TIG,
              is it possible to make it a single undo?
                Yes. πŸ˜•
                But This way you can step back, undoing just the explode and then the various splits.
                Just find the model.start_operation()...model.commit_operation code and add a leading #
                Leave the first start_op and the last commit_ unchanged...
                • Rich O BrienR Online
                  What about an option to uniformly scale each item about it's center via a picked/inputted value?
                  • soloS Offline
                    I like this.
                    I am wondering if we could get different shapes, not too many long shards. Also is we could control the explode distances in future.
                      driven
                      running enroth's erode on each piece adds to the effect of a rock wall...
                      • pbacotP Offline
                        Holy Grail
                        • jujuJ Offline
                          juju
                          @pbacot said:
                          Holy Grail
                          yeah, but i was thinking holy something else...
                            This plugin is not working for the MAKE version ?
                            • massimoM Offline
                              massimo Moderator
                              Fracture | SketchUcation
                              (sketchucation.com)
                              • KrisidiousK Offline
                                Krisidious
                                Dude... I can use this for Stained Glass. Nice TIG.
                                By: Kristoff Rand
                                  Dependencies: Pro
                                  Ah! curious maybe because that use some solids functions πŸ˜„
                                    Here's v3.0 http://sketchucation.com/pluginstore?pln=TIG_Fracture
                                    It now has three options to set constraints for the splitting around the XYZ axes, 0 to 1.
                                    The nearer to 0 the 'flatter' the split on that axis.
                                    With all three set to 1 it's entirely random.
                                    Play with their interrelationships to see the effects.
                                    Also now there are three 'Form' options:
                                    • Stacked - all parts left in place
                                    • Exploded - all parts from the center
                                    • Scaled - each part by ~90% to leave gaps
                                      If a non-Stacked Form is chosen it is separately undo-able.
                                      All of the Fragmentation is now undo-able in one step.
                                      Excellent....
                                      [edg3d:2r4rerg8]Kkw7hxg8YhQU3ne[/edg3d:2r4rerg8]
                                      Another request that if there's materials in the model you can choose which material get assigned to the faces sliced faces?
                                        Option for have only boxes ?
                                          Voxelize?
                                          • deaneauD Offline
                                            deaneau
                                            cool TIG..this plugin and sketchyPhysics could be a dream team πŸ‘ πŸ‘ πŸ‘
