    🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    VRAY causing Sketchup 2015 to bug splat
    renderpluginsextensions
    12 Posts 5 Posters 2.2k Views 5 Watching
      SuperFly
      Hi guys - been struggling with an issue for days now with no luck. I also posted this in the vray forum but no luck, so i figured the Bug section may be more appropriate.
      Just upgraded to Sketchup pro 2015 from 2014 and as soon as i install vray (the latest demo version at this stage) it causes a bug splat any time i try to open or save a sketchup file. Even trying to save a blank file it will error.
      If i double click on a skp file it will open, but i am not able to save it.
      If i uninstall vray it works fine. if i disable the vray extension it will still bug splat.
      This is on windows 7 64bit.
      I have tried everything can think of; uninstalled and reinstalled countless times, search both the hard disk and registry for any references to vray or sketchup and removed them, still no good.
      Is there any way to see in the bug splat dump files exactly what the issue is? They seem somehow encoded, or certainly not readable to me.
      Open to any ideas as i am dead in the water right now!
      UPDATES:
      I built a brand new virtual machine running the same version of Windows as my laptop and SU2015 and vray runs fine, using the same install files.
      I also thought maybe it was because i has SU2014 and the older vray installed first, so i installed this onto my VM, uninstalled and reinstalled SU2015 and its still fine.
      Still no closer to working out whats actually going on.
        SuperFly
        OK somehow i managed to post this in the wrong category - can a mod move it to the Bugs section please?
        • ShyamscoolS Offline
          Shyamscool
          I have been running into the same issue. sketchup doesnt crash when you hit ctrl+s. It bugsplats when you go to 'save as', or try to change material in vray material editor.
          Win 7 64 bit.
          I have tested this on 3 different computers now. Using a different copy of sketchup and vray every time. No success. I even tried going back to older versions of skp15.
          Whats going on?
            Shyamscool
            File New
            File New
            ======== Starting GL ========
            CBaseGLView::OnInitialUpdate
            InitializeOpenGL
            GetActivePixelFormat
            requestedpf.accel=1
            ARB functions NOT available.
            nPfds=402
            Pixel format 6 does not do a swap copy.
            Pixel format 7 does not do a swap copy.
            Pixel format 8 does not do a swap copy.
            Pixel format 9 does not do a swap copy.
            Pixel format 10 does not do a swap copy.
            Pixel format 11 does not do a swap copy.
            Pixel format 18 does not do a swap copy.
            Pixel format 19 does not do a swap copy.
            Pixel format 20 does not do a swap copy.
            Pixel format 21 does not do a swap copy.
            Pixel format 22 does not do a swap copy.
            Pixel format 23 does not do a swap copy.
            Pixel format 30 does not do a swap copy.
            Pixel format 31 does not do a swap copy.
            Pixel format 32 does not do a swap copy.
            Pixel format 33 does not do a swap copy.
            Pixel format 34 does not do a swap copy.
            Pixel format 35 does not do a swap copy.
            Pixel format 42 does not do a swap copy.
            Pixel format 43 does not do a swap copy.
            Pixel format 44 does not do a swap copy.
            Pixel format 45 does not do a swap copy.
            Pixel format 46 does not do a swap copy.
            Pixel format 47 does not do a swap copy.
            Pixel format 54 does not do a swap copy.
            Pixel format 55 does not do a swap copy.
            Pixel format 56 does not do a swap copy.
            Pixel format 57 does not do a swap copy.
            Pixel format 58 does not do a swap copy.
            Pixel format 59 does not do a swap copy.
            Pixel format 66 does not do a swap copy.
            Pixel format 67 does not do a swap copy.
            Pixel format 68 does not do a swap copy.
            Pixel format 69 does not do a swap copy.
            Pixel format 70 does not do a swap copy.
            Pixel format 71 does not do a swap copy.
            Pixel format 78 does not do a swap copy.
            Pixel format 79 does not do a swap copy.
            Pixel format 80 does not do a swap copy.
            Pixel format 81 does not do a swap copy.
            Pixel format 86 does not do a swap copy.
            Pixel format 87 does not do a swap copy.
            Pixel format 88 does not do a swap copy.
            Pixel format 89 does not do a swap copy.
            Pixel format 94 does not do a swap copy.
            Pixel format 95 does not do a swap copy.
            Pixel format 96 does not do a swap copy.
            Pixel format 97 does not do a swap copy.
            Pixel format 102 does not do a swap copy.
            Pixel format 103 does not do a swap copy.
            Pixel format 104 does not do a swap copy.
            Pixel format 105 does not do a swap copy.
            Pixel format 110 does not do a swap copy.
            Pixel format 111 does not do a swap copy.
            Pixel format 112 does not do a swap copy.
            Pixel format 113 does not do a swap copy.
            Pixel format 114 does not do a swap copy.
            Pixel format 115 does not do a swap copy.
            Pixel format 128 does not do a swap copy.
            Pixel format 129 does not do a swap copy.
            Pixel format 130 does not do a swap copy.
            Pixel format 131 does not do a swap copy.
            Pixel format 132 does not do a swap copy.
            Pixel format 133 does not do a swap copy.
            Pixel format 140 does not do a swap copy.
            Pixel format 141 does not do a swap copy.
            Pixel format 142 does not do a swap copy.
            Pixel format 143 does not do a swap copy.
            Pixel format 144 does not do a swap copy.
            Pixel format 145 does not do a swap copy.
            Pixel format 152 does not do a swap copy.
            Pixel format 153 does not do a swap copy.
            Pixel format 154 does not do a swap copy.
            Pixel format 155 does not do a swap copy.
            Pixel format 156 does not do a swap copy.
            Pixel format 157 does not do a swap copy.
            Pixel format 164 does not do a swap copy.
            Pixel format 165 does not do a swap copy.
            Pixel format 166 does not do a swap copy.
            Pixel format 167 does not do a swap copy.
            Pixel format 168 does not do a swap copy.
            Pixel format 169 does not do a swap copy.
            Pixel format 176 does not do a swap copy.
            Pixel format 177 does not do a swap copy.
            Pixel format 178 does not do a swap copy.
            Pixel format 179 does not do a swap copy.
            Pixel format 180 does not do a swap copy.
            Pixel format 181 does not do a swap copy.
            Pixel format 188 does not do a swap copy.
            Pixel format 189 does not do a swap copy.
            Pixel format 190 does not do a swap copy.
            Pixel format 191 does not do a swap copy.
            Pixel format 192 does not do a swap copy.
            Pixel format 193 does not do a swap copy.
            Pixel format 200 does not do a swap copy.
            Pixel format 201 does not do a swap copy.
            Pixel format 202 does not do a swap copy.
            Pixel format 203 does not do a swap copy.
            Pixel format 208 does not do a swap copy.
            Pixel format 209 does not do a swap copy.
            Pixel format 210 does not do a swap copy.
            Pixel format 211 does not do a swap copy.
            Pixel format 216 does not do a swap copy.
            Pixel format 217 does not do a swap copy.
            Pixel format 218 does not do a swap copy.
            Pixel format 219 does not do a swap copy.
            Pixel format 224 does not do a swap copy.
            Pixel format 225 does not do a swap copy.
            Pixel format 226 does not do a swap copy.
            Pixel format 227 does not do a swap copy.
            Pixel format 232 does not do a swap copy.
            Pixel format 233 does not do a swap copy.
            Pixel format 234 does not do a swap copy.
            Pixel format 235 does not do a swap copy.
            Pixel format 236 does not do a swap copy.
            Pixel format 237 does not do a swap copy.
            Pixel format 250 does not do a swap copy.
            Pixel format 251 does not do a swap copy.
            Pixel format 252 does not do a swap copy.
            Pixel format 253 does not do a swap copy.
            Pixel format 254 does not do a swap copy.
            Pixel format 255 does not do a swap copy.
            Pixel format 262 does not do a swap copy.
            Pixel format 263 does not do a swap copy.
            Pixel format 264 does not do a swap copy.
            Pixel format 265 does not do a swap copy.
            Pixel format 266 does not do a swap copy.
            Pixel format 267 does not do a swap copy.
            Pixel format 274 does not do a swap copy.
            Pixel format 275 does not do a swap copy.
            Pixel format 276 does not do a swap copy.
            Pixel format 277 does not do a swap copy.
            Pixel format 278 does not do a swap copy.
            Pixel format 279 does not do a swap copy.
            Pixel format 286 does not do a swap copy.
            Pixel format 287 does not do a swap copy.
            Pixel format 288 does not do a swap copy.
            Pixel format 289 does not do a swap copy.
            Pixel format 290 does not do a swap copy.
            Pixel format 291 does not do a swap copy.
            Pixel format 298 does not do a swap copy.
            Pixel format 299 does not do a swap copy.
            Pixel format 300 does not do a swap copy.
            Pixel format 301 does not do a swap copy.
            Pixel format 302 does not do a swap copy.
            Pixel format 303 does not do a swap copy.
            Pixel format 310 does not do a swap copy.
            Pixel format 311 does not do a swap copy.
            Pixel format 312 does not do a swap copy.
            Pixel format 313 does not do a swap copy.
            Pixel format 314 does not do a swap copy.
            Pixel format 315 does not do a swap copy.
            Pixel format 322 does not do a swap copy.
            Pixel format 323 does not do a swap copy.
            Pixel format 324 does not do a swap copy.
            Pixel format 325 does not do a swap copy.
            Pixel format 330 does not do a swap copy.
            Pixel format 331 does not do a swap copy.
            Pixel format 332 does not do a swap copy.
            Pixel format 333 does not do a swap copy.
            Pixel format 338 does not do a swap copy.
            Pixel format 339 does not do a swap copy.
            Pixel format 340 does not do a swap copy.
            Pixel format 341 does not do a swap copy.
            Pixel format 346 does not do a swap copy.
            Pixel format 347 does not do a swap copy.
            Pixel format 348 does not do a swap copy.
            Pixel format 349 does not do a swap copy.
            Pixel format 354 does not do a swap copy.
            Pixel format 355 does not do a swap copy.
            Pixel format 356 does not do a swap copy.
            Pixel format 357 does not do a swap copy.
            Pixel format 358 does not do a swap copy.
            Pixel format 359 does not do a swap copy.
            ChoosePixelFormat returning 197
            GLConfigUtils::GetActivePixelFormat ... returning 197
            Make a context ... pf=197
            Got context @3eebb30 error=0
            GL initialization succeeded
            Tool(SelectionTool)
            UseHWAccelerationFirstTime
            Got vendor (NVIDIA Corporation) renderer(Quadro K5000/PCIe/SSE2)
            Returning 1
            Loaded ruby file: extensions.rb
            Loaded ruby file: langhandler.rb
            Loaded ruby file: sketchup.rb
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_advancedcameratools/advancedcameratools_main.rbs
            Loaded ruby file: C:/Users/shyamj/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools/actloader.rb
            Loaded ruby file: su_advancedcameratools.rb
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcfunctions_v1.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclassifier.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_overlays.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dctools.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcutils.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcconverter.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbs
            Loaded ruby file: C:/Users/shyamj/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rb
            Loaded ruby file: su_dynamiccomponents.rb
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/geometryhelpers.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/meshhelpers.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/triangulatorutility.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/fromcontours.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/fromscratch.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/smoovetool.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/stamptool.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/drapetool2.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/detailtool.rbs
            Loaded ruby file: c:/users/shyamj/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/flipedgetool.rbs
            Loaded ruby file: C:/Users/shyamj/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_sandbox/sandboxmenus.rb
            Loaded ruby file: su_sandbox.rb
            Loaded ruby file: C:/Users/shyamj/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_webtextures/webtextures_loader.rb
            Loaded ruby file: su_webtextures.rb
            Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Properties)Commit(8)
            Start(Properties)Commit(9)
            Start(Properties)Commit(10)
            Start(Properties)Commit(11)
            Start(Properties)Commit(12)
            Start(Properties)Commit(13)
            Start(Properties)Commit(14)
            Start(Properties)Commit(15)
            Start(Properties)Commit(16)
            Start(Properties)Commit(17)
            Start(Macro)Start(Properties)Commit(19)
            Start(Properties)Commit(20)
            Start(Properties)Commit(21)
            Start(Properties)Commit(22)
            Start(Properties)Commit(23)
            Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Properties)Commit(28)
            Start(Properties)Commit(29)
            Start(Properties)Commit(30)
            Start(Properties)Commit(31)
            Start(Properties)Commit(32)
            Start(Properties)Commit(33)
            Start(Properties)Commit(34)
            Start(Properties)Commit(35)
            Start(Properties)Commit(36)
            Start(Properties)Commit(37)
            Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Properties)Commit(44)
            Start(Properties)Commit(45)
            Start(Properties)Commit(46)
            Start(Properties)Commit(47)
            Start(Properties)Commit(48)
            Start(Properties)Commit(49)
            Start(Properties)Commit(50)
            Start(Properties)Commit(51)
            Start(Properties)Commit(52)
            Start(Properties)Commit(53)
            Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Properties)Commit(62)
            Start(Properties)Commit(63)
            Start(Properties)Commit(64)
            Start(Properties)Commit(65)
            Start(Properties)Commit(66)
            Start(Properties)Commit(67)
            Start(Properties)Commit(68)
            Start(Properties)Commit(69)
            Start(Properties)Commit(70)
            Start(Properties)Commit(71)
            Start(Properties)Commit(72)
            Start(Properties)Commit(73)
            Start(Properties)Commit(74)
            Start(Properties)Commit(75)
            Start(Properties)Commit(76)
            Start(Macro)Start(Properties)Commit(78)
            Start(Properties)Commit(79)
            Start(Properties)Commit(80)
            Start(Properties)Commit(81)
            Start(Properties)Commit(82)
            Start(Properties)Commit(83)
            Start(Properties)Commit(84)
            Start(Properties)Commit(85)
            Start(Properties)Commit(86)
            Start(Properties)Commit(87)
            Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Macro)Start(Properties)Commit(196)
            Start(Properties)Commit(197)
            Start(Properties)Commit(198)
            Start(Properties)Commit(199)
            Start(Properties)Commit(200)
            Start(Properties)Commit(201)
            Start(Properties)Commit(202)
            Start(Properties)Commit(203)
            Start(Properties)Commit(204)
            Start(Properties)Commit(205)
            Start(Properties)Commit(206)
            Start(Properties)Commit(207)
            Start(Properties)Commit(208)
            Start(Properties)Commit(209)
            Start(Properties)Commit(210)
            Start(Properties)Commit(211)
            Start(Properties)Commit(212)
            Start(Properties)Commit(213)
            Start(Properties)Commit(214)
            Start(Properties)Commit(215)
            Start(Properties)Commit(216)
            Start(Properties)Commit(217)
            Start(Properties)Commit(218)
            Start(Properties)Commit(219)
            Start(Properties)Commit(220)
            Start(Properties)Commit(221)
            Start(Properties)Commit(222)
            Start(Properties)Commit(223)
            Start(Properties)Commit(224)
            Start(Properties)Commit(225)
            Start(Properties)Commit(226)
            Start(Properties)Commit(227)
            Start(Properties)Commit(228)
            Start(Properties)Commit(229)
            Start(Properties)Commit(230)
            Start(Properties)Commit(231)
            Loaded ruby file: C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb
            Loaded ruby file: vfs.rb
            Tool(SelectionTool)
            ***** First UI thread = 6920
              Shyamscool
              Anybody have any idea of whats going on?
              • P Offline
                Philw
                I am having Bug Splats as well lately and as i am finding out other issues tied to V Ray http://sketchucation.com/forums/viewtopic.php?f=79%26amp;t=62580%26amp;p=573573#p573573
                When I render and changes views a couple of time it will bug splat with in a session. I am also using Windows 7 and SKU15
                • TedVitale_CGT Offline
                  TedVitale_CG
                  Please email support@chaosgroup.com with issues like these.
                  Ted Vitale
                  Owner | Creative Director
                  http://www.voxl.vision
                    Shyamscool
                    Yeah, I contacted them. They say that the cant recreate the issue I am talking about. So what happens when they say they cant recreate the bugsplat?
                      TedVitale_CG
                      Email support again with the header "ATTN Ted - CG USA" and Ill see what I can do to get you sorted.
                      Ted Vitale
                        Shyamscool
                        Hi Ted,
                        I have discovered that this problem is arising only after the computers are added to our company domain. We have a new IT guy and I think the method/steps he is using to do this is causing the problem. Does that make any sense?
                        • V Offline
                          valerostudio
                          How are you bringing in your old plugins for 2014? When I went to 2015 I had to fresh install everything. No copy and pasting from the Plugins folder, that was too messy. Fresh install every plugin from the Extension Warehouse and the SketchUcation toolbar. Its painful at first but a good clean way to start with 2015.
                            Shyamscool
                            valerostudio, what you say is right.
