    Error message
    4 Posts 3 Posters 511 Views 3 Watching
    • D
      danna
      How do I get rid of the error message below when sketchup starts up ?
      http://webpages.charter.net/dandrafting/SUerror.jpg
        remove the roof framingplugin from your plugins folder and any associated folders it may need.
        • S
          slbaumgartner
          To clarify Rich's reply: you have the RoofFraming.rb file in your plugins folder, and it is trying but failing to load because you do not have its supporting files in the RoofFraming subfolder. It can't load without them. Most likely you installed the plugin manually rather than via the Extensions mechanism?
          • D
            danna
            Thanks guys ... that fixed it.
