    Pipe/tube along path
    7 Posts 6 Posters 1.4k Views 6 Watching
    • M
      Mike W
      Back in SketchUp 6 or so I had a plug-in called tube along path and also one called pipe along path. I cannot find those anywhere now. I sure would like to find them or something else that has the same functionality.
      Either one would draw a pipe or tube of the specified ID/Od/number of segments down any path, curved or around right angle corners.
      Push/Pull fails if the pattern is not perpendicular to the line and Follow Me takes off on odd tangents and I cannot get it to follow a line past more than one turn.
      Any ideas will be greatly appreciated.
      Thanks!
      Mike W
        Hi Mike,
        If you go here....
        404 Not Found
        (sketchucation.com)
        and type pipe you'll get....
        http://sketchucation.com/pluginstore?listtype=1%26amp;author=0%26amp;category=0%26amp;search=pipe%26amp;submit=%3F
        and if you type tube....
        http://sketchucation.com/pluginstore?listtype=1%26amp;author=0%26amp;category=0%26amp;search=tube%26amp;submit=%3F
        I'd recommend using our SketchUcation Tools πŸ‘
        404 Not Found
        (sketchucation.com)
        • cottyC
          cotty
          I've found these with a search after "path" and "tubes" in the pluginstore:
          • http://sketchucation.com/pluginstore?pln=PipeAlongPath
          • http://sketchucation.com/pluginstore?pln=lines2tubes
          Edit: same idea as Rich, but some seconds slower πŸ˜’
          my SketchUp gallery
          • genma saotomeG
            genma saotome
            "tube along path" isn't there.
              http://www.3skeng.com/en/index.htm πŸ˜‰
              Pipe tools like above but free! By Builder Boy πŸ˜‰
                Easy enough to find, though. Tube Along Path On the other hand TIG has kept Pipe Along Path up to date. Just use it.
                • M
                  Mike W
                  Thanks guys!
                  Pipe along path works just like I remembered and saved a ton of work.
                  Mike W.
