    Pipe/tube along path
    7 Posts 6 Posters 1.1k Views 6 Watching
      Mike W
      Back in SketchUp 6 or so I had a plug-in called tube along path and also one called pipe along path. I cannot find those anywhere now. I sure would like to find them or something else that has the same functionality.
      Either one would draw a pipe or tube of the specified ID/Od/number of segments down any path, curved or around right angle corners.
      Push/Pull fails if the pattern is not perpendicular to the line and Follow Me takes off on odd tangents and I cannot get it to follow a line past more than one turn.
      Any ideas will be greatly appreciated.
      Mike W
        Hi Mike,
        If you go here....
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        and type pipe you'll get....
        (sketchucation.com)
        and if you type tube....
        (sketchucation.com)
        I'd recommend using our SketchUcation Tools πŸ‘
        Plugin Store Download | SketchUcation
        Extending SketchUp has never been easier with a suite of tools that make installing and disabling plugins and extensions a one click operation.
        (sketchucation.com)
        • cottyC Offline
          cotty
          I've found these with a search after "path" and "tubes" in the pluginstore:
          • http://sketchucation.com/pluginstore?pln=PipeAlongPath
          • http://sketchucation.com/pluginstore?pln=lines2tubes
          Edit: same idea as Rich, but some seconds slower πŸ˜’
          my SketchUp gallery
          • genma saotomeG Offline
            genma saotome
            "tube along path" isn't there.
              http://www.3skeng.com/en/index.htm πŸ˜‰
              Pipe tools like above but free! By Builder Boy πŸ˜‰
                Easy enough to find, though. Tube Along Path On the other hand TIG has kept Pipe Along Path up to date. Just use it.
                  Mike W
                  Thanks guys!
                  Pipe along path works just like I remembered and saved a ton of work.
                  Mike W.
