    Material editor in sketchup 2015 using a mac
    18 Posts 6 Posters 3.7k Views 6 Watching
    • R
      rads2012
      Hi - Can anyone help?
      I am using a mac and the material editor is somewhat different to a pc (and looks somewhat less functional) so mac helpers please:
      I want to create new lists that I can add basic colours, with these colours I can then add further material attributes using the Thea render plugin. Each colour I want to give a new name and be able to save this list so I can add my own custom materials to my models (which have the Thea render attributes in them).... however:
      1. I cannot see any way of adding a basic colour - it allows me to add a material but then opens up a finder window on my mac (what am I meant to be adding here).
      2. No way of simply copying and renaming materials as far as I can see
      3. Also I want to delete the custom blocks at the bottom of the menu (or at least clear them) - is there a way?
      Thanks in advance
      S
      • S
        slbaumgartner
        To be brutally frank, I find the materials editor on Mac to be the worst-designed and worst-documented aspect of SketchUp. I'll be watching this topic to see whether others can answer your questions!
        • D
          driven
          Select any existing color list to move colors from...
          drag a swatch from the color swatch at the top of the Color Picker to the row of swatches at the bottom.
          select List >> New and name your list...
          drag a swatch from of swatches at the bottom to your list window...
          1. No way of simply copying and renaming materials as far as I can see
          right click on a color in your list select edit, rename and close...
          1. Also I want to delete the custom blocks at the bottom of the menu (or at least clear them) - is there a way?
          To remove a color, drag an empty (white/light_grey) swatch onto a colored swatch to β€œerase” it.bit like this...
          Remembering to 'Close' after 'Edit' is the trickiest bit...
          john
          • ntxdaveN
            ntxdave
            OK - How do you do that in Windows? I just created 2 named colors and saved them to My Colors (I thought) but when I select My Colors nothing shows up.
            Press F1...thank me later
              Dave, on the PC, it's a bit easier.
              First, create a local collection.
              Add it to your favorites so it'll show in the future.
              Open the secondary pane in the Materials window by clicking on the icon in the upper right corner below the X for closing the window. Set one window to the In Model library. The other to the My colors library. It doesn't matter which library is display in which pane.
              Drag the thumbnails from In Model to My colors.
              • D
                driven
                but that's 'Colors in Model' save, the OP was request making a generic list for any model...
                I think mac is simpler a 'Colors in Model' save...Duplicate and name...john
                  If you have a collection of colors/materials in a model, choose Save collection as... and save it locally. Add it to favorites as above, if you wish. No big deal.
                  • R
                    rads2012
                    Many thanks for the help on this - it helped a great deal.
                    I did find editing the colours would not allow me to rename them - the only way I could achieve this was to duplicate the colour and give it a new name and then delete the old colour from the list.
                    Let's hope trimble make the mac editor more like the pc version in later editions.
                      SketchUp on Mac uses the Mac-supplied color editor.
                      • ntxdaveN
                        ntxdave
                        Thanks @Dave R, I had created the "My Colors" but then had not drug the colors down to the list - DUH!! 😳 😳
                          Must be the drugs. πŸ˜„
                          • ntxdaveN
                            ntxdave
                            I have a material collection that is "My Colors". Now I have some silly questions:
                            1. Where is that stored? (Yes, I looked under Window>Preferences>Files>Materials and it is not there).
                            2. How do I delete it? (Yes, I tried clicking on Remove from favorites and it was not listed there)
                              It's probably under your Username/App Data?Roaming/SketchUp 2015...
                              • ntxdaveN
                                ntxdave
                                Was not there....I did a search on the entire system for "my" and it was not found.
                                Here is what I am trying to remove:
                                  Well, now you've done it.
                                  Is it in Program Files/SketchUp...?
                                  Did you try searching for one of the texture files? Or search for *.skm and see if that turns up anything.
                                  • ntxdaveN
                                    ntxdave
                                    Yes, that is where it was.....interesting that File Explorer did not find it.
                                    No, I did not try looking for .skm files. Would probably have been a better search. I just deleted the folder and all is back to normal. I think that I will set something like this up in the future as it would give me a more consistent set of colors to use in my equipment models (components). That could save some headaches and reduce file sizes as I look at creating equipment layouts and using one of the web browsers in the future.
                                    Seems like everyday I pick up some kind of little trick that can make use of SU easier and better. πŸ˜„ πŸ˜„
                                    • pbacotP
                                      • D
                                        driven
                                        @rads2012 said:
                                        ...I did find editing the colours would not allow me to rename them - the only way I could achieve this was to duplicate the colour and give it a new name and then delete the old colour from the list.
                                        what's the renaming convention you are hoping to apply?
                                        there may be other ways to do it...
                                        john
