    Profile Builder 2
    22 Posts 14 Posters 10.0k Views 14 Watching
      alpro
      Now available in the extension warehouse at an introductory price
      • K Offline
        kaas
        How could I have missed this one. Just tested it. Its absolutely wonderful! Many enhancements over PB1 pro (one of my most used plugins). This one will save you even more time. Great work!! 👍 👍
        • JQLJ Offline
          JQL
          This is an absolutely brilliant plugin!
          www.casca.pt
          Visit us on facebook!
            AcesHigh
            The demo looks awesome, but there are some improvements that could be made... or maybe I just don´t know how to use it properly yet.
            Let´s say you want to build a fence with a wire mesh.
            You set the poles as components. But it seems the plugin was made so the parts connecting the two components should be profiles, otherwise they won´t properly connect in more complex patterns.
            Here...
            I created two components... the concrete pole and the wire mesh, which is a surface with some ondulation for more realism
            http://i.imgur.com/1EOuBxK.jpg
            Now, this is what happens when using the Plugin. The mesh component, which should connect every two poles, is only rotated in the X and Y directions...
            http://i.imgur.com/hrv6yNG.jpg
            And this is what I would like the plugin to do. I did this manually. I placed the mesh component at an anchor point at the concrete pole. Rotated it horizontally (plugin already does it) so it would properly connect to anchor point in next pole. Then with FREDOSCALE I stretched it to reach the anchor point of next pole (when distance between poles was not exact.
            And the most important: I used Fredoscale PLANAR SHEARING, so the connection would be perfect. If this plugin could automatically do these steps I described above, including the shearing, it would be perfect.
            http://i.imgur.com/rMnd5y7.jpg
            • W Offline
              Whaat
              Hi Aces,
              That's a difficult one to do with the plugin. In general, it is designed for profiles to be used to connect the components. You should be able to create a polyline profile for the wire mesh instead of a component but it won't be as realistic as what you are trying to achieve. Thanks for the feedback!
                AcesHigh
                @whaat said:
                Hi Aces,
                Whaat, wouldn´t you be able to achieve that by using code similar to FredoScale's Planar Shearing? It´s easy to think of other things that would benefit from it, like electricity poles connected by electrical wires (the wires would be an arc... planar shearing them when the poles have different heights would be better looking than rotating the arcs)
                  agrazdi
                  Sometimes when applying a change of the profile size, a BUG SPLAT is produced.
                  Have you noticed ??
                  • tt_suT Offline
                    tt_su
                    Have you noticed ??
                    Did you submit the BugSplats? If you didn't, can you please do? And did you enter any info in the description or name that I can use to look it up?
                    • W Offline
                      Whaat
                      Have you noticed ??
                      Hello,
                      Please describe exactly what you did to reproduce the splat. PB2 was in beta testing for 5 weeks and there was not one report of any bug-splats. If this is caused by PB2, I will try and release a fix as soon as possible.
                      Thanks for the report!
                      • W Offline
                        Whaat
                        @aceshigh said:
                        @whaat said:
                        Hi Aces,
                        I'll certainly look into this if I keep getting requests for this feature. Thanks!
                          agrazdi
                          @whaat said:
                          Have you noticed ??
                          Hello,
                          • P Offline
                            psylo
                            I used a lot the first ProfileBuilder, so I just purchased the second edition as it seems very, very promising ...
                            I'm just playing with it for a couple of minute and I have a couple of question :
                            • when I build an "assembly" and close the path, the first post on the junction disappear ...
                            • can we edit an "assembly" path afterward ?
                            Thanks.
                              dtrarch
                              Install refused 4 times.
                              How about just a simple time bombed rbz.
                              dtr
                              • W Offline
                                Whaat
                                dtr
                                Hi, Can you post some details here, please? Thanks!
                                Site Not Found - Discourse
                                (forums.sketchup.com)
                                • pbacotP Offline
                                  Is this in the SCF plugin store? I never go to Trimble or use Google login myself.
                                    nope
                                    • pbacotP Offline
                                      Guess I'll have to start...
                                        cadmunkey
                                        Bought this yesterday, I use PB1 a ton so this is a superb update. Thanks to all involved!
                                          dtrarch
                                          Load fail 👎 👎
                                          5th time.
                                          dtr
                                          • W Offline
                                            Whaat
                                            Thanks agrazdi,
                                            I'll fix this ASAP. Look for an update sometime next week. Thanks for the report!
                                            • 1 / 2
