    Profile Builder 2
    22 Posts 14 Posters 9.8k Views 14 Watching
      AcesHigh
      @whaat said:
      Hi Aces,
      That's a difficult one to do with the plugin. In general, it is designed for profiles to be used to connect the components. You should be able to create a polyline profile for the wire mesh instead of a component but it won't be as realistic as what you are trying to achieve. Thanks for the feedback!
      Whaat, wouldn´t you be able to achieve that by using code similar to FredoScale's Planar Shearing? It´s easy to think of other things that would benefit from it, like electricity poles connected by electrical wires (the wires would be an arc... planar shearing them when the poles have different heights would be better looking than rotating the arcs)
        agrazdi
        Sometimes when applying a change of the profile size, a BUG SPLAT is produced.
        Have you noticed ??
        • tt_suT Offline
          tt_su
          Have you noticed ??
          Did you submit the BugSplats? If you didn't, can you please do? And did you enter any info in the description or name that I can use to look it up?
          • W Offline
            Whaat
            Have you noticed ??
            Hello,
            Please describe exactly what you did to reproduce the splat. PB2 was in beta testing for 5 weeks and there was not one report of any bug-splats. If this is caused by PB2, I will try and release a fix as soon as possible.
            Thanks for the report!
            • W Offline
              Whaat
              @aceshigh said:
              @whaat said:
              Hi Aces,
              I'll certainly look into this if I keep getting requests for this feature. Thanks!
                agrazdi
                @whaat said:
                Have you noticed ??
                Hello,
                  psylo
                  I used a lot the first ProfileBuilder, so I just purchased the second edition as it seems very, very promising ...
                  I'm just playing with it for a couple of minute and I have a couple of question :
                  • when I build an "assembly" and close the path, the first post on the junction disappear ...
                  • can we edit an "assembly" path afterward ?
                  Thanks.
                    dtrarch
                    Install refused 4 times.
                    How about just a simple time bombed rbz.
                    dtr
                    • W Offline
                      Whaat
                      dtr
                      Hi, Can you post some details here, please? Thanks!
                      Profile Builder 2 trial : installation problem
                      Hello, It seems it’s not possible to install Profile Builder 2 trial. Does anyone have the same problem ? Thank you so much. Kind regards, Jean-Luc
                      SketchUp Community (forums.sketchup.com)
                      • pbacotP Offline
                        Is this in the SCF plugin store? I never go to Trimble or use Google login myself.
                          nope
                          • pbacotP Offline
                            Guess I'll have to start...
                              cadmunkey
                              Bought this yesterday, I use PB1 a ton so this is a superb update. Thanks to all involved!
                                dtrarch
                                Load fail 👎 👎
                                5th time.
                                dtr
                                • W Offline
                                  Whaat
                                  Thanks agrazdi,
                                  I'll fix this ASAP. Look for an update sometime next week. Thanks for the report!
                                    Citelum
                                    Profile Builder 2 is great!
                                    I am using it to draw road layouts from profiles of the cross-section of a road with curbs and sometimes a median as well. The road extrudes beautifully along lines but when you join another road or have a road crossing the curbing and median follows right through the other road.
                                    Is there any way to have these joints/crossings show up as a normal road would? When you follow a corner the road behaves correctly and extends one edge and reduces the other edge, so could the curbing and medians be removed automatically at crossings and junctions?
                                      db11
                                      Whaat -
                                      Is there a particular reason you don't offer Profile Builder 2 through the Sketchucation Plugin Store? I really object to having to create a Google account in order to purchase through the Extension Warehouse, but I'm keen on purchasing your plugin.
