    Is it possible to do an incremental Save?
    17 Posts 7 Posters 2.7k Views 7 Watching
    • chippwaltersC
      chippwalters
      Lots of 3D programs these days allow for a shift-command+S to SAVE with a version number appended. While this can result in lots of disk space being used, it also helps with workflow-- especially if you need to 'go back in time' to access a template or reference object-- or find out you accidentally deleted something 3 saves ago.
      Is there a plugin or other feature I don't know about which allows for this? Thanks!
      Currently working with Cross-Reality technologies
        Hi Chipp,
        Save a Copy As does this.
        • chippwaltersC
          chippwalters
          @rich o brien said:
          Hi Chipp,
          Hi Rich,
          Much thanks for answering...
          But it's not really what I'm after. Want I would like is for it to
          Save the file, but append an incremental number to it. So, if a file was fred.skp it would save it as: fred_01.skp, then it would USE the newly saved file. So, in the titlebar of Sketchup, it would show fred_01.skp until I incrementally saved again, then it would say fred_02.skp.
          That's pretty much the workflow I'm looking for. Do you know if this is possible?
            I think there's a plugin that can do something like that. Archiver sticks in my head but i disremember the author. Maybe TIG?
            Edit: my memory is better than I remembered.
            http://sketchucation.com/pluginstore?pln=Archiver
            • JQLJ
              JQL
              @rich o brien said:
              Hi Chipp,
              Hi Chipp,
              www.casca.pt
              Visit us on facebook!
              • chippwaltersC
                chippwalters
                @jql said:
                @rich o brien said:
                Hi Chipp,
                Hi Chipp,
                When I "Save a Copy As" there is no incremental save NOR is the newly saved version loaded into SketchUp. Am I missing something?
                • chippwaltersC
                  chippwalters
                  Thanks Dave,
                  Almost there. Unfortunately it only archives and does not load the archived version into SketchUp. Still, it's the best so far!
                    Have you tried File>Save as...? You'd have to supply the 01, 02, etc.
                    • chippwaltersC
                      chippwalters
                      Hi Dave,
                      Yes, that is the feature, but I'd prefer having it as a single click or keyboard shortcut. I've gotten in the habit in other 3D programs to just hit a keyboard shortcut and it automatically incrementally saves. I think I'll try the previous solution you suggested. Thanks!!
                        Save a Copy As
                        Saves a copy suffixed with #
                        It also keeps your working model with the original name.
                        So in essence the original is the master and the suffixed # versions are the saved steps along the way
                        • JQLJ
                          JQL
                          @chippwalters said:
                          @jql said:
                          @rich o brien said:
                          Hi Chipp,
                          Hi Chipp,
                          Sorry chippwalters, my bad. I didn't understand what you wanted to say with incremental save and just couldn't resist the small joke... I didn't want to upset you but I simply couldn't resist.
                          I hope I didn't offend you and now that I understand it I see the usefulness.
                          More seriously I would advice anyone to do as Rich is suggesting, because that way you keep the same file name for the file you're working with. It's an old habit I got from CAD, when the files I was working on would be referenced in bigger drawings. It's still valid for sketchup if you break the bigger model in smaller parts. Like a masterplan and several houses...
                          www.casca.pt
                          • chippwaltersC
                            chippwalters
                            @rich o brien said:
                            Save a Copy As
                            Hmmm
                            Mine just saves a copy with the word "copy" appended. In any case, I'm using the fine Archiver plugin mapped to Shift+S.
                            Thanks everyone for the superb help!!
                            • D
                              driven
                              @chipp
                              you should add mac to the topic titles and fill in your profile...
                              if I had known it was for a mac I would have suggested a using a 'folder action' that saves incremental copies without using SU to do it...
                              You can basically say, whenever a file in folder 'xxx' is updated, create copy of file 'filename.appended'...
                              I don't have one up my sleeve but it's very common to find these on the internet...
                              john
                              • chippwaltersC
                                chippwalters
                                @driven said:
                                @chipp
                                john
                                Good idea! Thanks John. I'll update my prefs now.
                                • chippwaltersC
                                  chippwalters
                                  Well, it turns out folderactions can't do the job. They're evidently broke when it comes to 'acting' upon the same named file in the same folder.
                                  I'll keep looking. Thanks anyway.
                                  • M
                                    massta
                                    This would be a great feature. I know I know, "save as" works but it slows workflow. Better to have it automatically increment. When done for the day, the user can delete at will. Houdini and Touch Designer work this way and has saved me a bunch of times.
                                    • TIGT
                                      Already linked earlier in this thread, my Archiver:
                                      A easy shortcut from the File menu...
