    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 121.5k Views 39 Watching
    • CadFatherC Offline
      CadFather
      hi Dave, sure
        Does the Power Tool bar has new plugins inside or it's grouping plugins yet existing ?
          CadFather
          it contains existing plugins. some near the original version - and many have been tweaked or even re-written (back in 2015).
            Thx for the explantions! ☀
              jamesfrees
              Mine says that jhs and the fix file are not models and can not be opened, I have updated everything
                Extensions are not models and are not installed by opening in SketchUp. What version of SketchUp are you actually using? Your profile says you are using SketchUp 2019 Free/Make but there is no such version.
                  berylho
                  I'm using 19.3 version, but even I have downloaded the newest version of the Powerbar, the tool bar still isn't showing...and there is no error message either.
                  • jujuJ Offline
                    juju
                    Have you checked View > Toolbars to see if there is a checkmark next to its entry?
                      I don't have any use for it but I just installed it in SU2019.3 to see what would happen. I clicked the Install button and nearly instantly, the toolbar appeared at the top of the model window.
                        arielkarmi
                        Im using sketchup 2020 on a Mac. Installed the extension but cant find the tools. Its also showing as an unsigned extension. I tried to install 2019. Same issue.
                        Any advice?
                          Apocan
                          indiremiyorum yardımcı olurmusunuz ?
                          • jujuJ Offline
                            juju
                            bless your soul
                            • Y Offline
                              yjanssen
                              Does not work on sketchup 2020 pro...
                              does not come up
                                Actually it does work just fine in SketchUp 2020.
                                Make sure you've installed the correct version.
                                  darkhelmet
                                  Thx to @cadfather for this awesome plugin. I kinda figured out most of the functionality however I don't understand how Rotix works - it shows the 3 planes in the upper left, but how do I then rotate an object?
                                    rv1974
                                    @juju said:
                                    bless your soul
                                    Universal approach. It must get sticky in FAQ 😄
                                      maxosmedia
                                      Hi Max! Great thanks for you beautiful JHSPowerbar!
                                      But... after install it, sketchup loses the ability to execute the standard command " customize toolbar" (RMB on gray plate on the top of viewport" and similarly: view/ customize toolbar.sketchup is frozen until "force quit"...
                                      JHS POWERBAR 2020 v2020.1
                                      Sketchup 22.0. 353
                                      Mac OsX 13.0.1
                                      Apple MiPro 2021
                                      there is no such problem on the 2014 machine:
                                      Sketchup 22.0. 353
                                      Mac OsX 13.0.1
                                      macbookpro (retina, 15 inch, early 2013, intel)
mac os x 10.15.7
                                      <<< ---the extension works fine and does not create problems for the Sketchup main functionality
                                        CadFather
                                        unfortunately i don't have a mac on which to test the bugs.
                                        if any mac using author wants to have a look, that's fine.
                                        time is a bit tight, but hope to update JHSPB sometime in late february if i can.
                                        meantime, i just thought that you can edit manually the toolbar file:
                                        "jhs_pb_settings.txt"
                                        true means the icon will show, false it is hidden.
                                        if you reference the list with the image below, you can make it easier to see which icons will checked (true) or not (false).
                                        • 4 / 4
