    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 134.3k Views 39 Watching
    • B
      berylho
      I'm using 19.3 version, but even I have downloaded the newest version of the Powerbar, the tool bar still isn't showing...and there is no error message either.
      • jujuJ
        juju
        Have you checked View > Toolbars to see if there is a checkmark next to its entry?
          I don't have any use for it but I just installed it in SU2019.3 to see what would happen. I clicked the Install button and nearly instantly, the toolbar appeared at the top of the model window.
            arielkarmi
            Im using sketchup 2020 on a Mac. Installed the extension but cant find the tools. Its also showing as an unsigned extension. I tried to install 2019. Same issue.
            Any advice?
              Apocan
              indiremiyorum yardımcı olurmusunuz ?
              • jujuJ
                juju
                bless your soul
                • Y
                  yjanssen
                  Does not work on sketchup 2020 pro...
                  does not come up
                    Actually it does work just fine in SketchUp 2020.
                    Make sure you've installed the correct version.
                      darkhelmet
                      Thx to @cadfather for this awesome plugin. I kinda figured out most of the functionality however I don't understand how Rotix works - it shows the 3 planes in the upper left, but how do I then rotate an object?
                        rv1974
                        @juju said:
                        bless your soul
                        Universal approach. It must get sticky in FAQ 😄
                          maxosmedia
                          Hi Max! Great thanks for you beautiful JHSPowerbar!
                          But... after install it, sketchup loses the ability to execute the standard command " customize toolbar" (RMB on gray plate on the top of viewport" and similarly: view/ customize toolbar.sketchup is frozen until "force quit"...
                          JHS POWERBAR 2020 v2020.1
                          Sketchup 22.0. 353
                          Mac OsX 13.0.1
                          Apple MiPro 2021
                          there is no such problem on the 2014 machine:
                          Sketchup 22.0. 353
                          Mac OsX 13.0.1
                          macbookpro (retina, 15 inch, early 2013, intel)
mac os x 10.15.7
                          <<< ---the extension works fine and does not create problems for the Sketchup main functionality
                          • CadFatherC
                            CadFather
                            unfortunately i don't have a mac on which to test the bugs.
                            if any mac using author wants to have a look, that's fine.
                            time is a bit tight, but hope to update JHSPB sometime in late february if i can.
                            meantime, i just thought that you can edit manually the toolbar file:
                            "jhs_pb_settings.txt"
                            true means the icon will show, false it is hidden.
                            if you reference the list with the image below, you can make it easier to see which icons will checked (true) or not (false).
                            • 4 / 4
