    CFileException 5
    7 Posts 4 Posters 2.5k Views 4 Watching
      ania1sun
      %(#4080FF)[Hi there,
      I wanted to save my SketchUp drawing but the information "CFileException" appeard on the screen and the saved file dind't update. Why ?]
        You running file off a USB stick or external drive?
          slbaumgartner
          CFileException 5 means "access denied", i.e. a permissions problem. As Rich notes, this is known to sometimes happen with USB or other external locations of a file.
            I think can happen if your autosave file was externally and then you, for some reason, moved to local.
            So the autosave continues to try and locate a path to 0.skb that it can no longer find.
              ania1sun
              %(#4080FF)[Its at the same location on hard drive all the time.
              Can it be because I have that file in Google Drive ( cloud storage )Folder which updates every time I click SketchUp drawing to Save the changes ?]
                If it is on your google drive, that could be a problem. If the file is saved in the cloud, it isn't on your hard drive.
                  ania1sun
                  %(#4040FF)[It is on my hard drive and in the cloud. I had that problem becouse file was being updated when I was trying to save it. I turned up automatic update to cloud and the problem dissapeared πŸ˜ƒ
                  Thanx anyway =)]
                  quote="Dave R"]If it is on your google drive, that could be a problem. If the file is saved in the cloud, it isn't on your hard drive.[/quote]
