    HDRI Light splotches problem
    renderpluginsextensions
    7 Posts 5 Posters 2.1k Views 5 Watching
    • G
      gianfranco_bm
      Hi everyone, I thought I was already getting a handle on HDRIs, but when I found the right one for my scene, I got these light splotches. When rotating the HDRI (both in GI and BG) the splotches move. I was wondering if it's necessary to make a blurred copy of the original HDRI and use it for the GI. Or is there any other easier solution? Thx!
      Vray version: 2.00.25244
      Sketchup 2015
      http://s11.postimg.org/y0l4tkg3n/RINCONADA_V1b.jpg
      • V
        valerostudio
        Do not use an HDRI in your GI or BG. In 2.0 you have to create a dome light. This will fix the problem.
        • olisheaO
          olishea
          Kinda looks cool though! Sorry for the lack of constructive input haha
          oli
          • majidM
            majid
            If you are using HDR images, make a small blurred copy and also increase the HS subdivide to let me say 50 or more
            • G
              gianfranco_bm
              Thanks, I hadn't seen that video. I think in it, they forget to mention to turn off/delete the HDRI in the GI and BG, but it is as you say. Problem solved πŸ‘
              • V
                valerostudio
                This is a good trick if you are not using 2.0. But I would say, moving forward with VR2, all HDRIs should be used with a dome light. You will not need the extra subdivs on your IR map. If you have a lot of noise in the image, increase the subdivs of the dome light.
                • R
                  rv1974
                  It was recommended million times:
                  check sub-pixel mapping and clamp output;
                  uncheck reflective caustics.
