    Problem with 100 sides circle and fallow me tool
    4 Posts 4 Posters 427 Views 4 Watching
      chitan
      I have trouble to make sphere with 100 sides circle and fallow-me tool!
      I always get unfinished sphere.... no top!... top side of sphere is always open...
      What to do?
        I assume you mean the Follow Me tool. You're working at too small of a size.
        Try scaling your model up by a factor of 100 or even 1000 before running Follow Me.
        • kenK Offline
          ken
          I work with piping. I make it a point to always have the number of segments to evenly divided in to whole degrees. So as an example, I use for extra fine detail, 360 segments for 360 degrees, 1 seg/per/deg, 180, 2 seg/per/deg. Also as Dave indicates, scaling up always help.
          If I going to divide a pipe segment into to some other degrees, I always make sure the division is made at full degrees.
          Just my two cents worth.
          Ken
            SketchUp's built-in tolerance is 1/1000"
            If your initial circle's segment length results in FollowMe geometry edges of shorter than 1/1000", then they won't get made - because SketchUp assumes the two ends are coincident and so skips on.
            Then any dependent facets also get omitted etc...
            This occurs in any operation making new geometry - like the native FollowMe, Intersect etc and any similar Plugins...
            As was said before... Scale up temporarily to avoid these issues.
