    Alpha texture problem
    2 Posts 2 Posters 260 Views 2 Watching
    • D
      devilreborn
      Hi all,
      I ran into a problem when applying partially transparent textures to a sketchup model.
      I have two different textures of trees painted onto three separate faces, as shown below:
      However, if I change the camera angle so that the faces now overlap, the problem appears.
      There are some transparent areas incorrectly displayed so that you can see through all 3 faces instead of showing the second face behind.
      Both textures are stored in 32-bit TGA format (with an alpha channel). I have also tried to convert the textures to PNG but the same problem persists.
      • K
        kaas
        Displaying layered transparencies is a bit harder (more calculations) for render engines. Have you tried changing the style settings to transparency - nicer ?
