    Yellow bounding box
    5 Posts 4 Posters 2.6k Views 4 Watching
      suSteve
      why is the bounding box yellow in this model?
      thank you
      • BoxB Offline
        Because the modeller chose to have his bounding boxes yellow. Probably a pre SU7 model.
        Edit: here you go, download this and it should be carpenter style with a yellow bounding box. If it isn't then I'm wrong. You change the selection colour in the style edit dialog.
        Yellow Bounding.skp
          suSteve
          thank you - yes it is yellow. I wondered if it was anything special about the model but it isn't
          thanks again
            Ye olde versions of SketchUp [<v7?] had templates that used 'yellow' to highlight a selected object or bounds.
            Newer SketchUp versions changed that to a 'blue' default.
            Your Style can set any color you desire for these kinds of things...
            For example the shipped-default setting for locked bounds is now a 'pinkish red'... but again that's customizable...
            See Style > Edit > Modeling Settings...
            Personally - my own default templates use an 'amber' highlight color...
            • Wo3DanW Offline
              Wo3Dan
              thanks again
              The 'Selected' color can be changed as mentioned above and will also be saved per scene, much like different 'Section Cuts' colors.
