    Target material in group to see in Material Editor
    renderpluginsextensions
    8 Posts 5 Posters 842 Views 5 Watching
      LARV
      Let´s say I import a large object containing several groups and many different materials.
      I want to target one of these in the material editor, but I can´t find the specific material among 30 others in the Material Editor because the material doesn´t have a specific name, let´s say, "Gun turret". It might be named "material 34" or whatever.
      Sometimes I can select a material and then open the Material Editor and the material will be highlighted. But this doesn´t always happen.
      What´s the easiest way to find a specific material in the Material Editor?
      Thanks!
      • Rich O BrienR Online
        Use ALT+Left Button to sample face
        • V Offline
          valerostudio
          I think I also asked the Chaos guys a long time ago to add an eyedropper shortcut to the material editor. Might be a plugin out there, but the paint bucket + alt works like a charm. I think this will be a Doh! moment for LARV.
          • dkendigD Offline
            dkendig
            yes, you did request that, but we decided at the time that the built in SketchUp workflow should be sufficient.
            Devin Kendig
            Developer
              LARV
              WELL, LOOK AT THAT!! Thanks!
                LARV
                [attachment=0:2iajmzzn]<!-- ia0 -->material-picker.gif<!-- ia0 -->[/attachment:2iajmzzn]
                I tried clicking on a material with ALT+left button but I didn´t see anything happening. Tried it and then opened the Material editor and the material marked was still a material I had marked previously.
                EDIT: Hold on, I have attached pictures blocked. I now see that you have a picture named "material picker". I suspect you were giving me the same advice as the other guy. Thanks! Got it!
                  driven
                  are you seeing the gif yet?
                  and have you got the eye-droper working...
                  if not, the missing information for someone flying blind...
                  is to first select 'Paint Bucket Tool', then Use ALT+Left Button to sample face
                  john
                    LARV
                    Yes I got it! Thanks
