    [req] random polygon division and guide points @ vertices
    12 Posts 6 Posters 1.3k Views 6 Watching
      john2
      Is there a plugin that divides my irregularly shaped plane into multiple polygons of random size? Actually I am using the Voronoi plugin and need to speed up things.
      Another requirement, a plugin that places guide points at various vertices selected
        To add guide-points at every selected vertex copy/paste + <enter> this in the Ruby Console.
        m=Sketchup.active_model;a=m.active_entities;s=m.selection;vs=((s.grep(Sketchup;;Edge).collect{|e|e.vertices})+(s.grep(Sketchup;;Face).collect{|e|e.vertices})).flatten.uniq;m.start_operation('x');vs.each{|v|a.add_cpoint(v)};m.commit_operation
        It's one step undo-able. It finds vertices from selected edges and/or faces and places a guide-point on each one... Note how it can use a 'vertex' and does not need 'vertex.position' to place the cpoint...
          john2
          Is it possible to make a plugin out of this? πŸ˜‰ It is indeed I suppose. ❓ Actually I find ruby console quite technical and programmo-expert sort of thing. So, that's why, Im asking for a plugin for a novice like me.
            It just needs adding to some code:
            require 'sketchup.rb'
            module TIG
            def self.cpoint_vertices()
            Copy paste it into a file named say TIG-cpoint_vertices.rb in the Plugins folder.
            It must be 'UTF8 without BOM' encoded to suit Ruby - you might need Notepad++.exe [free download] to be able to do that on a PC, as the built-in Notepad.exe might not automatically do that encoding...
            When that file loads it makes the command that can be run from the Ruby Console:
            TIG.cpoint_vertices
            I expect you want a menu item too... add this extra code to the above module - just before its final ' end'...
            unless file_loaded?(__FILE__)
              UI.menu('Plugins').add_item('#{self}.cpoint_vertices'){ self.cpoint_vertices() }
            file_loaded(__FILE__)
            It then appears in the 'Plugins' menu [retitled 'Extensions' under v2015].
            That allows you to 'shortcut' it...
            • BoxB Offline
              Works for me with normal notepad.
                I have Notepad++ set for all text editing, so I was unsure.
                I just re-enabled Notepad.exe and checked.
                If you accept its save-default of "ANSI" and then open it in Notepad++ it reports as "UTF8 without BOM" 0 so it's OK !
                Which is interesting... πŸ˜•
                So you can use Notepad.exe to edit/make RB files.
                Just make sure it has the .rb file-type suffix, so that SketchUp recognizes it as a Ruby file as it starts and loads all of the scripts from the Plugins folder... πŸ€“
                I still recommend Notepad++ - it has lots of goodies, like syntax coloring in files like RB... πŸ˜„
                • F Offline
                  fredo6
                  You can use MarVertices which is part of FredoTools.
                  It works on a selection.
                  Fredo
                  • F Offline
                    fredo6
                    Are you looking for a Voronoi plugin? And what do you mean "Seep up things"?
                    Fredo
                      john2
                      Fredo
                      I am using the voronoi plugin, the latest one. Well, I need polygon division quickly done automatically for a given surface. I have to manually divide it into polygons. "Seep up things?" , I wrote "Speed up things" i.e. to make the process of polygon division faster.
                        Looks like someone is already building a future classic!
                        • P Offline
                          And this little thing ?
                          Not exactly totally automatic but funny! β˜€
                          Protrude by Jim Foltz
                          Random Painter by Chris Fullmer
                            john2
                            superb! πŸ‘ I want to do that stuff exactly. How should I do it?
