    Scripting help. Where to start.....
    20 Posts 2 Posters 1.1k Views 2 Watching
    • O Offline
      o0rico0o
      Hi Guys, I'm working on a form finding project with a local community group. The project will be similar to the projects of Julian Wild (http://www.julianwild.com/making-the-connection/) in which members of the community come together and connect pieces of timber together to form a structure.
      As a start I have created a kit of components shown in the following image.
      The colors relate to a specific joint type i.e. red - dovetail joint (end to end), blue, - right angled joint, black, t- joint.
      These joints will be cut using a robotic arm and will enable the members to connect together in a specific way.
      Depending on the order in which these members will be connected, the form will change. An example of one of the many form options is shown below.
      The above example is just one option, I need to ideally write a script that will place the pieces together and explore many more of the possible options.
      Do you think is possible?
      Thanks for your help in advance.
      Rico
      • sdmitchS Offline
        sdmitch
        Rico
        As is often said, "anything is possible". Here is the code I used to create the image
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        # create a 3d node network
        nodes = []
        for z in 0..5
         for y in 0..5
          for x in 0..5
           nodes << Geom;;Point3d.new(x.to_s.to_l,y.to_s.to_l,z.to_s.to_l)
        #randomly connect nodes
        until nodes.empty?
         node = nodes[rand(nodes.length)]
         try = 0
         begin
          near = nodes[rand(nodes.length)]
          dist = node.distance near
          try += 1
         end until ((dist>0 && dist<='1.75'.to_l) || try==nodes.length)
         if try < nodes.length
          cdn = ['Black-Black','Blue-Blue','Green-Green','Yellow-Yellow','Red-Red']
          cd = mod.definitions[cdn[rand(cdn.length)]]
          ci = ent.add_instance(cd,Geom;;Transformation.new())
          tr = Geom;;Transformation.scaling('1'.to_l,'1'.to_l,dist)
          ci.transform! tr
          vector = node.vector_to(near).normalize
          xa,ya,za = vector.axes
          tr = Geom;;Transformation.axes(node,xa,ya,za)
          ci.transform! tr
         nodes.delete(node)
        This is a strictly random placement but should give you an idea or two.
        http://sdmitch.blogspot.com/
        • O Offline
          o0rico0o
          Wow, this is almost exactly what I am looking to do. How can I learn the basics to coding like this? Is there a way that this script could be edited to make that it produces something that is structurally sound?
          • sdmitchS Offline
            sdmitch
            Get a Ruby programming reference book and study to code of every plugin you have for examples. This is what I did 3 years ago.
            Edited to make it produce something that is structurally sound? Maybe someone could but not me.
            • O Offline
              o0rico0o
              Ok great, I may do just that. In the mean time would it be possible for you to send the skp file over so that I could see what you started with?
              • O Offline
                o0rico0o
                Using your script this is what Im getting so far....
                Initial Blocks....
                Result....
                Do you know what I am doing wrong?
                • sdmitchS Offline
                  sdmitch
                  Model has been sent by Private Message.
                  • O Offline
                    o0rico0o
                    Great thanks for the PM, I understand the process alot better now! Final question, do you know how I could edit the script to make sure that all elements have at least one connection and that there would be no dead ends?
                    • sdmitchS Offline
                      sdmitch
                      This code should get close if not there.
                      sel = mod.selection
                      nodes = []; nhsh = {}
                      for z in 0..5
                       for y in 0..5
                        for x in 0..5
                         nhsh[nodes.last]=0
                      mps = []; loops = 0
                      until nodes.empty?
                       loops += 1; break if loops>999
                       Sketchup.set_status_text "loop #{loops}"
                       try = 0
                       begin
                        try += 1; dist=0
                        unless node==near
                         mp = Geom;;Point3d.linear_combination(0.5,node,0.5,near)
                         unless mps.include?(mp)
                       end until ((dist>0 && dist<='1.75'.to_l) || try>nodes.length)
                       if (dist>0 && dist<='1.75'.to_l && try<=nodes.length)
                        cdn = ['Black-Black','Blue-Blue','Blue-Black','Green-Green','Green-Blue', \
                        'Green-Black','Yellow-Yellow','Yellow-Green','Yellow-Blue','Yellow-Black', \
                        'Red-Red','Red-Yellow','Red-Green','Red-Blue','Red-Black']
                        ci.transform! tr
                        ci.transform! tr
                        mod.active_view.refresh
                        mps << mp
                        nhsh[node] += 1
                        nodes.delete(node) if nhsh[node]>2# at least two connections
                      • O Offline
                        o0rico0o
                        Great, thank you for all of your help! I'm really sorry to keep asking you to push this further! I have two more questions.
                        1. Currently the script is locating each block at a random point within the predefined cube. Can this cube be removed so that the structure is free to grow in any direction ( on second thoughts maybe removing the ability to grow in the -z plane direction?
                        2. If this process was replicated in the physical word we would have to build from the bottom, securing the structure as we go. If we were to build it, the construction process would be similar to that of a growing tree (for every incremental increase in height there is an increase in the diameter), this helps the structure to retain its integrity. Could this process be replicated? So that the script builds from the bottom -up?
                        As always thanks again for your help, I really appreciate it!
                        • sdmitchS Offline
                          sdmitch
                          1. I would assume so but probably produce some very weird results. Not sure what "-z plane direction" is.
                          2. Not sure why the order of creation would effect the construction. Varying the "diameter" of the pieces from level to level would be easy enough to do.
                          • O Offline
                            o0rico0o
                            1. I'm all about the weird results! when I said '-z direction' I was referring to nothing below the ground plane.
                            2. I was thinking in terms of varying the diameter of the overall structure, to create an overall form that is similar to that of a truncated square pyramid.
                            3. my original image also allows for T connections. how easy would it be to integrate this into the script?
                            • sdmitchS Offline
                              sdmitch
                              This code creates a path which can get a little weird. Plus it varies the "diameter" relative to the height.
                              > sel = mod.selection
                              > for z in 0..5
                              >  for y in 0..5
                              >   for x in 0..5
                              >    nhsh[nodes.last]=0
                              >   end
                              >  end
                              > end
                              > #random connected path
                              > begin
                              >  node = nodes[rand(nodes.length)];#pick starting node
                              > end until node.z==0
                              > mps = []; loops = 0;
                              > loop do
                              >  try = 0;dist=0
                              >  begin
                              >   try += 1
                              >   unless near==node
                              >    dist = node.distance(near)
                              >    unless (dist > '1.75'.to_l || mps.include?(mp))
                              >     mps << mp
                              >     break
                              >    end
                              >   end
                              >  end until try==nodes.length
                              >   cdn = ['Black-Black','Blue-Blue','Blue-Black','Green-Green','Green-Blue','Green-Black','Yellow-Yellow','Yellow-Green','Yellow-Blue','Yellow-Black','Red-Red','Red-Yellow','Red-Green','Red-Blue','Red-Black']
                              >   xys = '1'.to_l * (1.0 + (3.0-node.z)/10.0)#vary diameter relative to height
                              >   tr = Geom;;Transformation.scaling(xys,xys,dist)
                              >   ci.transform! tr
                              >   ci.transform! tr
                              >   Sketchup.active_model.active_view.refresh
                              >  else
                              >   puts "trys exceeded nodes"; return
                              >  end
                              >  node = near
                              >  loops += 1; break if loops > 250
                              >  Sketchup.set_status_text "Segment #{loops}"
                              > end
                              1. I was thinking in terms of varying the diameter of the overall structure, to create an overall form that is similar to that of a truncated square pyramid.
                              This code variation produces something like a pyramid.
                              for z in 0..3
                              >  for y in z..5-z
                              >   for x in z..5-z
                              1. my original image also allows for T connections. how easy would it be to integrate this into the script?
                              Nothing I do prevents "T" connections.
                              • O Offline
                                o0rico0o
                                Brilliant this is perfect! The only issue that I'm having is that the model is too small, How can I change the script to make the individual elements 50x50x800mm? Thanks again!
                                • sdmitchS Offline
                                  sdmitch
                                  Unless you eliminate all diagonal elements, they can't all be 800mm.
                                  • O Offline
                                    o0rico0o
                                    No thats fine, I don't mind variation, I was just wondering how to adapt the script to work at a larger scale. At the moment the elements are drawn at 0.2x0.2x3mm
                                    • sdmitchS Offline
                                      sdmitch
                                      This variation produces 50X50X800mm elements.
                                      sel = mod.selection
                                      for z in 0..5
                                       zz = (z*800.mm).to_s.to_l
                                       for y in 0..5
                                        yy = (y*800.mm).to_s.to_l
                                        for x in 0..5
                                         xx = (x*800.mm).to_s.to_l
                                         nodes << Geom;;Point3d.new(xx,yy,zz)
                                         nhsh[nodes.last]=0
                                      begin
                                      end until node.z==0
                                      loop do
                                       try = 0;dist=0
                                       begin
                                        try += 1
                                        unless near==node
                                         unless (dist > 1400.mm || mps.include?(mp))
                                          mps << mp
                                          break
                                      #  xys = '1'.to_l * (1.0 + (3.0-node.z)/10.0)
                                        tr = Geom;;Transformation.scaling(15.7480315,15.7480315,dist)
                                        ci.transform! tr
                                        ci.transform! tr
                                       else
                                        puts "trys exceeded nodes. dist=#{dist}"; #return
                                       node = near
                                      • O Offline
                                        o0rico0o
                                        Hmmmm, did it work for you? Im getting this?
                                        • sdmitchS Offline
                                          sdmitch
                                          [attachment=0:12yqg6cm]<!-- ia0 -->Screen Shot 2014-12-01 at 17.17.10.png<!-- ia0 -->[/attachment:12yqg6cm]
                                          Yes it works for me. Are you using the model I sent you? Have you created your own components? Have you changed the model units from inches?
                                          • O Offline
                                            o0rico0o
                                            Ahhh, yes, I changed It from inches to mm. That could be the issue, Thanks!
