    Scripting help. Where to start.....
    20 Posts 2 Posters 1.3k Views 2 Watching
    • O Offline
      o0rico0o
      Using your script this is what Im getting so far....
      Initial Blocks....
      Result....
      Do you know what I am doing wrong?
      • sdmitchS Offline
        sdmitch
        Model has been sent by Private Message.
        http://sdmitch.blogspot.com/
        • O Offline
          o0rico0o
          Great thanks for the PM, I understand the process alot better now! Final question, do you know how I could edit the script to make sure that all elements have at least one connection and that there would be no dead ends?
          • sdmitchS Offline
            sdmitch
            This code should get close if not there.
            mod = Sketchup.active_model
            ent = mod.active_entities
            sel = mod.selection
            # create a 3d node network
            nodes = []; nhsh = {}
            for z in 0..5
             for y in 0..5
              for x in 0..5
               nodes << Geom;;Point3d.new(x.to_s.to_l,y.to_s.to_l,z.to_s.to_l)
               nhsh[nodes.last]=0
            #randomly connect nodes
            mps = []; loops = 0
            until nodes.empty?
             loops += 1; break if loops>999
             Sketchup.set_status_text "loop #{loops}"
             node = nodes[rand(nodes.length)]
             try = 0
             begin
              try += 1; dist=0
              near = nodes[rand(nodes.length)]
              unless node==near
               mp = Geom;;Point3d.linear_combination(0.5,node,0.5,near)
               unless mps.include?(mp)
                dist = node.distance near
             end until ((dist>0 && dist<='1.75'.to_l) || try>nodes.length)
             if (dist>0 && dist<='1.75'.to_l && try<=nodes.length)
              cdn = ['Black-Black','Blue-Blue','Blue-Black','Green-Green','Green-Blue', \
              'Green-Black','Yellow-Yellow','Yellow-Green','Yellow-Blue','Yellow-Black', \
              'Red-Red','Red-Yellow','Red-Green','Red-Blue','Red-Black']
              cd = mod.definitions[cdn[rand(cdn.length)]]
              ci = ent.add_instance(cd,Geom;;Transformation.new())
              tr = Geom;;Transformation.scaling('1'.to_l,'1'.to_l,dist)
              ci.transform! tr
              vector = node.vector_to(near).normalize
              xa,ya,za = vector.axes
              tr = Geom;;Transformation.axes(node,xa,ya,za)
              ci.transform! tr
              mod.active_view.refresh
              mps << mp
              nhsh[node] += 1
              nodes.delete(node) if nhsh[node]>2# at least two connections
            • O Offline
              o0rico0o
              Great, thank you for all of your help! I'm really sorry to keep asking you to push this further! I have two more questions.
              1. Currently the script is locating each block at a random point within the predefined cube. Can this cube be removed so that the structure is free to grow in any direction ( on second thoughts maybe removing the ability to grow in the -z plane direction?
              2. If this process was replicated in the physical word we would have to build from the bottom, securing the structure as we go. If we were to build it, the construction process would be similar to that of a growing tree (for every incremental increase in height there is an increase in the diameter), this helps the structure to retain its integrity. Could this process be replicated? So that the script builds from the bottom -up?
              As always thanks again for your help, I really appreciate it!
              • sdmitchS Offline
                sdmitch
                1. I would assume so but probably produce some very weird results. Not sure what "-z plane direction" is.
                2. Not sure why the order of creation would effect the construction. Varying the "diameter" of the pieces from level to level would be easy enough to do.
                • O Offline
                  o0rico0o
                  1. I'm all about the weird results! when I said '-z direction' I was referring to nothing below the ground plane.
                  2. I was thinking in terms of varying the diameter of the overall structure, to create an overall form that is similar to that of a truncated square pyramid.
                  3. my original image also allows for T connections. how easy would it be to integrate this into the script?
                  • sdmitchS Offline
                    sdmitch
                    This code creates a path which can get a little weird. Plus it varies the "diameter" relative to the height.
                    > sel = mod.selection
                    > for z in 0..5
                    >  for y in 0..5
                    >   for x in 0..5
                    >    nhsh[nodes.last]=0
                    >   end
                    >  end
                    > end
                    > #random connected path
                    > begin
                    >  node = nodes[rand(nodes.length)];#pick starting node
                    > end until node.z==0
                    > mps = []; loops = 0;
                    > loop do
                    >  try = 0;dist=0
                    >  begin
                    >   try += 1
                    >   unless near==node
                    >    dist = node.distance(near)
                    >    unless (dist > '1.75'.to_l || mps.include?(mp))
                    >     mps << mp
                    >     break
                    >    end
                    >   end
                    >  end until try==nodes.length
                    >  if try < nodes.length
                    >   cdn = ['Black-Black','Blue-Blue','Blue-Black','Green-Green','Green-Blue','Green-Black','Yellow-Yellow','Yellow-Green','Yellow-Blue','Yellow-Black','Red-Red','Red-Yellow','Red-Green','Red-Blue','Red-Black']
                    >   xys = '1'.to_l * (1.0 + (3.0-node.z)/10.0)#vary diameter relative to height
                    >   tr = Geom;;Transformation.scaling(xys,xys,dist)
                    >   ci.transform! tr
                    >   ci.transform! tr
                    >   Sketchup.active_model.active_view.refresh
                    >  else
                    >   puts "trys exceeded nodes"; return
                    >  end
                    >  node = near
                    >  loops += 1; break if loops > 250
                    >  Sketchup.set_status_text "Segment #{loops}"
                    > end
                    1. I was thinking in terms of varying the diameter of the overall structure, to create an overall form that is similar to that of a truncated square pyramid.
                    This code variation produces something like a pyramid.
                    for z in 0..3
                    >  for y in z..5-z
                    >   for x in z..5-z
                    1. my original image also allows for T connections. how easy would it be to integrate this into the script?
                    Nothing I do prevents "T" connections.
                    • O Offline
                      o0rico0o
                      Brilliant this is perfect! The only issue that I'm having is that the model is too small, How can I change the script to make the individual elements 50x50x800mm? Thanks again!
                      • sdmitchS Offline
                        sdmitch
                        Unless you eliminate all diagonal elements, they can't all be 800mm.
                        • O Offline
                          o0rico0o
                          No thats fine, I don't mind variation, I was just wondering how to adapt the script to work at a larger scale. At the moment the elements are drawn at 0.2x0.2x3mm
                          • sdmitchS Offline
                            sdmitch
                            This variation produces 50X50X800mm elements.
                            sel = mod.selection
                            for z in 0..5
                             zz = (z*800.mm).to_s.to_l
                             for y in 0..5
                              yy = (y*800.mm).to_s.to_l
                              for x in 0..5
                               xx = (x*800.mm).to_s.to_l
                               nodes << Geom;;Point3d.new(xx,yy,zz)
                               nhsh[nodes.last]=0
                            begin
                            end until node.z==0
                            loop do
                             try = 0;dist=0
                             begin
                              try += 1
                              unless near==node
                               unless (dist > 1400.mm || mps.include?(mp))
                                mps << mp
                                break
                            #  xys = '1'.to_l * (1.0 + (3.0-node.z)/10.0)
                              tr = Geom;;Transformation.scaling(15.7480315,15.7480315,dist)
                              ci.transform! tr
                              ci.transform! tr
                             else
                              puts "trys exceeded nodes. dist=#{dist}"; #return
                             node = near
                            • O Offline
                              o0rico0o
                              Hmmmm, did it work for you? Im getting this?
                              • sdmitchS Offline
                                sdmitch
                                [attachment=0:12yqg6cm]<!-- ia0 -->Screen Shot 2014-12-01 at 17.17.10.png<!-- ia0 -->[/attachment:12yqg6cm]
                                Yes it works for me. Are you using the model I sent you? Have you created your own components? Have you changed the model units from inches?
                                • O Offline
                                  o0rico0o
                                  Ahhh, yes, I changed It from inches to mm. That could be the issue, Thanks!
