VRImg to EXR converter
hello can any one help me where can i find this converter?
http://charlottesvillearchitecturalrendering.com/?p=539
i have searched in internet but the only converter i find is the simple one where u drag vrimg on it, i want to render high resolution image with channels
This tool is new with vray 2.0
thank you
You can also open the .vrimg file directly in the Frame buffer and save it out as any file type you would like.
Is it possible (or can we get the ability) to save out a multi layered EXR from the VFB? Right now, the only way I know how to do it is to save direct to EXR via the Render to VRIMG feature.
you also can't save out vrimg from the frame buffer if you do a regular render, so I assume it has to do with rendering to vrimg in the first place.
yeah our vrimg format supports layers, I don't know if exr does. If it does, I suppose it's possible. I'm not sure if other flavors of V-Ray support this. If they do, then it's definitely possible.
(not sure you really need to worry about this now that we have 64bit support though)
Register LoginAdvertisement
