    VRImg to EXR converter
    renderpluginsextensions
    8 Posts 5 Posters 2.6k Views 5 Watching
    • I Offline
      imabzeous
      hello can any one help me where can i find this converter?
      http://charlottesvillearchitecturalrendering.com/?p=539
      i have searched in internet but the only converter i find is the simple one where u drag vrimg on it, i want to render high resolution image with channels
      • andybotA Offline
        andybot
        This tool is new with vray 2.0
        • I Offline
          imabzeous
          thank you πŸ˜„
          • TedVitale_CGT Offline
            TedVitale_CG
            You can also open the .vrimg file directly in the Frame buffer and save it out as any file type you would like.
            Ted Vitale
            Owner | Creative Director
            http://www.voxl.vision
            • V Offline
              valerostudio
              Is it possible (or can we get the ability) to save out a multi layered EXR from the VFB? Right now, the only way I know how to do it is to save direct to EXR via the Render to VRIMG feature.
              • andybotA Offline
                andybot
                you also can't save out vrimg from the frame buffer if you do a regular render, so I assume it has to do with rendering to vrimg in the first place.
                • dkendigD Offline
                  dkendig
                  yeah our vrimg format supports layers, I don't know if exr does. If it does, I suppose it's possible. I'm not sure if other flavors of V-Ray support this. If they do, then it's definitely possible.
                  Devin Kendig
                  Developer
                  • dkendigD Offline
                    dkendig
                    (not sure you really need to worry about this now that we have 64bit support though) πŸ˜‰
                    Devin Kendig
                    Developer
