    Error message
    9 Posts 4 Posters 761 Views 4 Watching
      jimbojuliette
      I get an error message when I try to create an object on layer 0 with no other layers visible.
      I have purged Layers and clicked on show hidden geometry in the View menu.
      The message reads "your recent operation has caused visible geometry to merge with existing geometry on a HIDDEN LAYER"
      I have deleted some layers. Could that cause the problem?
      My first question is: How do you "Hide" a layer. I know we can make a layer visible but that's not the same as hiding.
      Secondly: How so I UNHIDE a layer?
      I'm attaching the file:
      Jim
      segment sled.skp
        Jim, you need to spend some time learning about layers in SketchUp. Keep all of the geometry on Layer 0. Only make layer associations for components and/or groups.
        You've got geometry on a layer other than Layer 0 and you're drawing on Layer 0 so the geometry is merging. The only way to prevent geometry from merging with other geometry is to wrap it up in a component or group. Layers do not separate geometry. Layers only control visibility.
          Start here: http://help.sketchup.com/en/article/38572
            slbaumgartner
            For layers, "not visible" = "hidden", "visible" = "unhidden". The usual way to hide and unhide them is on the layers window.
              TECHDAVE02
              try this Six Rules for Modeling in SketchUp
              also play with this file with layers and outliner LAYER OUTLINER
              Six Rules for Modeling in SketchUp.pdf
              LAYER OUTLINER.skp
                jimbojuliette
                Once again, thank you gentlemen. I'm a Turbo CAD convert and layers is one of the differences I need to become familiar with. I made the base a component and the problem disappeared.
                  Did you move the geometry of the base back to Layer 0?
                    jimbojuliette
                    Dave;
                    I did and then I made it a group and put the group on the base layer.
                    Jim
                      Good work.
                      So remember to draw on Layer 0 only, make a component or group of the geometry and assign a layer to that component or group and everything should go smoothly.
