    Troubles With Toolbar Customization In SU 2015
    15 Posts 7 Posters 4.6k Views 7 Watching
    • F Offline
      fcborik
      Hello,
      I'm trying to convert over to SU2015 and I'm having a problem figuring out how to customize the toolbar. The SU help page says that I should go to view>toolbars>custom. but the "custom" never shows. I've attached a screenshot of what I see after I go to view>toolbars.
      Any help would be appreciated.
      Thanks!
      Frank Borik
      • F Offline
        fcborik
        Tried to attach the file again.
        • KrisidiousK Offline
          Krisidious
          you need to go to Toolbars.
          Click New.
          Name the toolbar.
          It will open.
          Use ctrl to drag and drop tools on to it.
          only native tools will work.
          you'll need one or more of the customtoolbar plugins to do anything with the other plugins.
          By: Kristoff Rand
            Frank, the process is exactly the same as for SU2014.
            • BoxB Offline
              Here is a little animation showing making a toolbar.
              Use Ctrl when you click and drag the tools so they make copies rather than drag them off the other toolbar. However it doesn't matter if you do drag them off by mistake because you only need to hit reset to get them back.
              Click to animate
                Krisidious
                Very nice Box...
                By: Kristoff Rand
                • BoxB Offline
                  @krisidious said:
                  Very nice Box...
                  I bet you say that to all the girls!
                    Krisidious
                    Never compliment a woman... They'll get all uppity and think they can do better than you. At least that's what my Dad taught me... He's single btw.
                    By: Kristoff Rand
                    • F Offline
                      fcborik
                      Forgot about the drag and drop. Many thanks for your help!
                      • Mistro11M Offline
                        Mistro11
                        Box- All these years I been using Sketchup and did not know we can do that... 😲
                        I have some rather large toolsets taking up valuable space where I only use 1 or 2 of the bunch. Now I know what to do. Thanks for that.
                        EDIT: Think I got excited too soon. Is it only the default tools that can be customized into a new toolbar? πŸ’š
                        i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                        Structural Integrity is Not Just Physical...It's in the Design and Purpose
                          Krisidious
                          You'll need the Toolbar Editor or Jim's Custom Toolbars to edit the others or both like i do..
                          By: Kristoff Rand
                            Ben Ritter
                            Box, How did you get your toolbars to be 2 columns wide at the left margin in SU2015?
                            Thanks.
                            • BoxB Offline
                              Thanks.
                              That is the default setting for the Large toolset, but it is the only one that will dock as two columns.
                                blackdogsketch
                                Man this is frustrating for something so simple. On 2016 Pro, the CTRL and drag does not work at all. Using ALT and drag just MOVES tools from the original toolbar. Frustrating.
                                  Ctrl+drag does indeed work for moving tools from the native toolbars to your custom toolbars. If it isn't working for you, check your keyboard. You do have to have the toolbars window open while customizing the toolbars.
                                  You can also just drag the tools over without holding Ctrl. If you want to restore the tools on the native toolbars, click on Reset.
