    Changes in 2015
    45 Posts 11 Posters 3.5k Views 11 Watching
      slbaumgartner
      @dan rathbun said:
      Bigger thumbnail = more loading time? (guessing)
      Seems unlikely to me unless it was programmed really badly. The thumbnail contains nothing that SketchUp needs for loading the file, so the loader should simply skip that part of the file with nearly zero impact on load time. Where a larger thumbnail would have an effect is on save or quit, when SU has to write the thumbnail. I think something else must be afoot, but at this point I have no clue what...
      Steve
      • tt_suT Offline
        tt_su
        @brighter3d said:
        Packing float value into two integers, and passing to double parameter function,
        seems no longer works in 64bit SU2015.
        passF = Win32API.new(mydll,"PassDouble",["L","L"],"V")
        packedF = [rubyFloat].pack("D").unpack("LL")
        passF.call(packedF[0],packedF[1])
        Any tips? 💭
        It's a bit vague - what exactly doesn't work of these calls? Do you see Ruby's packing methods returning different results?
        Is the DLL you are calling actually 64bit?
        Does the function you are calling actually use ints - or are you using some other type that might be different on 64bit OS?
        On a side note - the Win32API has been deprecated for a long time. It has many limitations and is easy to cause crashes with. The recommended now is using Fiddle.
        • tt_suT Offline
          tt_su
          @wbarnes05 said:
          I noticed the change regarding the Length class a few days ago in the API. What's weird is that the API states that the parent of Length is Object starting in SU 2015. That had me worried as it implies that mathematical operations will no longer work on an instance of Length. However everything continued to work ok in my plugin when running in SU 2015.
          I ran a few tests in 2015 and found the following:
          length = 4.to_l
          > 4"
          > length.is_a? Integer
          > false
          > length.is_a? Float
          > true
          > length.is_a? Length
          > true
          > length.class.superclass
          > Numeric
          > length.class.ancestors
          > [Length, Numeric, Comparable, Object, Kernel, BasicObject]
          It would appear then that the API is incorrect and should be changed to show that Numeric is the parent class.
          The API docs needs updating in general to make the hierarchy more clear. There are many inconsistencies. We have a big todo item to improve the whole developer site. Stay tuned.
          We had to pull some tricky shimming to prevent breaking stuff. I wasn't able to do a 100% compatibility, but I think we have a near 99% use case coverage. Main one is C Extensions doing low level type checks for Floats which used to work, but not any more.
          • tt_suT Offline
            tt_su
            @kaas said:
            @dan rathbun said:
            @kaas said:
            I just noticed in one of my plugins that loading a single small skp file (to use as a component definition) seems to take almost 1 second whereas the same code in SU 2014 loads the skp instantly.
            I can't imagine. The box.skp testfile I created was just a rectangle with an extrusion.
            Well, the simplicity of the model is one thing - but if out thumbnail generating code has become slower writing pixels then the model content doesn't matter...
            This is still on our todo list to investigate.
            • K Offline
              kaas
              just to be sure...My concern is not about writing skp files but about loading them. I don't see why it should be thumbnail issue.
                driven
                I ran a variation of your script in v13 and v15 on my mac...
                t = Time.now
                f = Sketchup.find_support_file('candle.skp', 'Components')
                d = Sketchup.active_model.definitions.load f
                puts (Time.now - t)
                #  all in different sessions of SU
                # v13 => 0.146086 , 0.037117, 0.022029
                # v15 => 0.033036, 0.046043,  0.013811
                test skp, not complex...
                john
                • Dan RathbunD Offline
                  Dan Rathbun
                  I was just guessing. The component browser DOES use the thumbnail if it is not set to display "List".
                  There used to be some time issues with thumbnails getting regenerated in the Component Browser.
                  Er.. or was that the Scene thumbnails ? It all blurs together.
                  I'm not here much anymore.
                    Brighter3D
                    Yes dll is 64bit, I was passing double value as a pair of two ints. On c++ side it was double parameter, and call was passF.call(packedF[0],packedF[1]) on ruby side.
                    That solves my problem, it does work now - thank you!
                    It is a pity that there is no fiddle on SU < 2014 (with old ruby),
                    and I need to use ancient Win32API.so method for backward compatibility.
                      Dan Rathbun
                      You can use DL which replaced Win32API.
                      https://github.com/DanRathbun/sketchup-ruby186-stdlib-extension/releases
                        Brighter3D
                        I still try to support SU 6 and 7...
                          Dan Rathbun
                          I don't.
                          Too many unfixed bugs, and they distro'd with Ruby 1.8.0 initial release, which is like 20 years old. (I wouldn't help anyone with 7 unless they'd replaced the Ruby DLL with a newer one, as I explained how to do in the "Ruby Resources" topic.)
                          Next year I'd say I will drop support for v8 and v2013, and be done with the old headaches that Ruby 1.8.x has, such as no unicode string support, etc.
                            Brighter3D
                            Maybe you are right...
                            For people doing renderings 2015 is first professional version (thanks to 64bit and possibility to use whole memory).
                            From the other side v8 is last true free version (according to the license)...
                            Do you know any recent statistics on SU versions usage?
                              Dan Rathbun
                              I've never heard Google or Trimble release any official numbers.
                              Some plugin authors have collected data on what versions are running their plugin(s) but it's not global.
                              Perhaps the SCF Plugin Store has data ?
                                SU6 and SU7 is very low. I wouldn't be too worried about trying to keep support for these versions in new releases. It's like trying to make a website for IE6 and 7 these days... 😉
                                There are some users still on SU8 - though it appear SU2013 users migrate faster. Not sure why that is. Maybe it's the Google => Trimble thing...
                                Personally I don't aim to support anything older than SU2014 any more - due to Ruby 2.0, standard lib and SU2014+ improvements. If my new releases will work on older it will be cause I didn't need to use the stdlib or any of the new SU2014+ features.
                                • K Offline
                                  kaas
                                  t = Time.now
                                  > puts (Time.now - t)
                                  john
                                  Thanks for looking into it. I tried your code on win32 and it loads the skp instantly. Great...but, plugins aren't installed in a sub-directory of the SketchUp installation directory anymore. Isn't it bad practice to put resources for a plugin in SketchUps installation directory instead of together with the code in the plugin directory?
                                  • tt_suT Offline
                                    tt_su
                                    DefinitionList.load Performance Tests:
                                    Test snippet:
                                    <span class="syntaxdefault">skp </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_support_file</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Car Sedan.skp'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Components/Components Sampler'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"DefinitionList.load Timing Tests"<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"> SketchUp Version; #{Sketchup.version}"<br /></span><span class="syntaxdefault">total </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0.0<br />iterations </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 10<br />iterations</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">times </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">  GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />  start_time </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now<br />  definition </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">load</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">skp</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  elapsed </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">now </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> start_time<br />  total </span><span class="syntaxkeyword">+=</span><span class="syntaxdefault"> elapsed<br />  puts </span><span class="syntaxstring">"> #{elapsed}; #{elapsed}"<br /></span><span class="syntaxdefault">  Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Remove Definition"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">clear</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">  Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br /></span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"> Average; #{total / iterations.to_f}"<br /></span><span class="syntaxcomment"># require File.join(ENV['HOME'] || ENV['HOMEPATH'], 'Desktop', 'definition_list_load_test.rb')<br />&nbsp;</span><span class="syntaxdefault"></span>
                                    > SketchUp Version; 15.0.9350
                                    > 0.023006; 0.023006
                                    > 0.037007; 0.037007
                                    > 0.036002; 0.036002
                                    > 0.034998; 0.034998
                                    > 0.035001; 0.035001
                                    > 0.035001; 0.035001
                                    > 0.036999; 0.036999
                                    > 0.035999; 0.035999
                                    > 0.035002; 0.035002
                                    > 0.035997; 0.035997
                                    > Average; 0.034501199999999996
                                    > SketchUp Version; 14.1.1282
                                    > 0.033001; 0.033001
                                    > 0.034001; 0.034001
                                    > 0.032002; 0.032002
                                    > 0.034003; 0.034003
                                    > 0.032001; 0.032001
                                    > 0.033003; 0.033003
                                    > 0.032002; 0.032002
                                    > 0.031001; 0.031001
                                    > 0.030007; 0.030007
                                    > 0.032006; 0.032006
                                    > Average; 0.032302700000000004
                                    > SketchUp Version; 13.0.4812
                                    > 0.038; 0.038
                                    > 0.033; 0.033
                                    > 0.033; 0.033
                                    > 0.03; 0.03
                                    > 0.03; 0.03
                                    > 0.03; 0.03
                                    > 0.03; 0.03
                                    > 0.03; 0.03
                                    > 0.03; 0.03
                                    > 0.03; 0.03
                                    > Average; 0.0314
                                    > SketchUp Version; 8.0.16846
                                    > 0.054; 0.054
                                    > 0.04; 0.04
                                    > 0.04; 0.04
                                    > 0.045; 0.045
                                    > 0.04; 0.04
                                    > 0.04; 0.04
                                    > 0.04; 0.04
                                    > 0.04; 0.04
                                    > 0.041; 0.041
                                    > 0.04; 0.04
                                    > Average; 0.042
                                    > SketchUp Version; 7.1.6860
                                    > 0.035; 0.035
                                    > 0.048; 0.048
                                    > 0.043; 0.043
                                    > 0.042; 0.042
                                    > 0.043; 0.043
                                    > 0.046; 0.046
                                    > 0.043; 0.043
                                    > 0.043; 0.043
                                    > 0.042; 0.042
                                    > 0.043; 0.043
                                    > Average; 0.0428
                                    I'm not seeing any performance regression - looks rather consistent on this end.. I'm not sure why you are seeing a difference on your system. ❓
                                    • jiminy-billy-bobJ Offline
                                      jiminy-billy-bob
                                      I have some data : http://thomashauchecorne.com/layers/analytics.php
                                      But it's only about Layers Panel users (around 500 unique daily users)
                                      • K Offline
                                        kaas
                                        Hi Thom, thanks for taking time to look at my code-problem.
                                        I don't see big differences as well if I load components from the SketchUp Components sub-folder (see my post, two posts above your post).
                                        Have you tried my original code (loading from root of C OR loading from the Sketchup plugins folder) and looked at the differences?
                                        I tested your code and here are the results:
                                        SketchUp Version: 15.0.9350
                                        0.06: 0.06
                                        0.04: 0.04
                                        0.05: 0.05
                                        0.04: 0.04
                                        0.040001: 0.040001
                                        0.04: 0.04
                                        0.05: 0.05
                                        0.04: 0.04
                                        0.04: 0.04
                                        0.04: 0.04
                                        Average: 0.0440001
                                        SketchUp Version: 14.1.1282
                                        0.02: 0.02
                                        0.02: 0.02
                                        0.02: 0.02
                                        0.02: 0.02
                                        0.02: 0.02
                                        0.02: 0.02
                                        0.02: 0.02
                                        0.02: 0.02
                                        0.02: 0.02
                                        0.02: 0.02
                                        Average: 0.019999999999999997
                                        • tt_suT Offline
                                          tt_su
                                          I still don't see any difference. Do you have a sample model to share?
                                            Dan Rathbun
                                            If a component has a classification assigned, the entire schema could be serialized into the skp file.
                                            Upon loading the schema is loaded into the active model, correct TT ?
                                            • 2 / 3
