    [Plugin] S4u Make Face
    56 Posts 28 Posters 275.1k Views 28 Watching
      Tantema
      This may or may not be relevant but I downloaded LibFredo6 along with Joint Push Pull and Tools on Surface to see how my installation would respond to having a helper Library. Well... same as before I downloaded them all. I went to Preferences and installed each .RBZ file. Then I restarted SU as an administrator and I got this error
      https://4.bp.blogspot.com/-GF6GvE1sdcM/W93okuDbv4I/AAAAAAAAAfM/LsB9lxUam1s0a7KFiFT12UDaTFj6t2hdQCLcBGAs/s640/error%2B2.JPG
      So I have repaired my .EXE file and I've installed the helper library and I'm still getting errors. Does anyone know what exactly is causing these errors and how can I correct them?
        RoRay
        installed in Sketchup 2017 works fine, so far.
        Very simple tool and terrifically useful. thanks!
        • wahyuesgroupW Offline
          wahyuesgroup
          now this extension in Pro Version 😎 , nice Mr Vi
          • N Offline
            nikki8889
            Hello,
            I have sketchup 2017.
            I have downloaded the s4u makeface, but it does not work now. It gives the message that"s4u is not active"
            I checked the extension manager but it has a tick on the plugin.
              aadya 11
              hello i have installed it but it is asking for activation file i have sketchup 2019 pro mac version
                Mercuriel
                Wasn't this extension free since 2004 ? it asks for licence.
                Now we've to buy this simple plugin, or code our own "makeface" and share it, or maybe this is a bug ? Anyone having explanation about the change reason ?
                  anoksha
                  its asking an activation code
                  • hdpvH Offline
                    hdpv
                    Trial and Purchase : https://www.sketchupforyou.com/purchase/s4u_makeface/
                    Suforyou
                    http://www.sketchupforyou.com
                      Munene
                      would you kindly consider making the make faces extensions free
                      • E Offline
                        Einstein
                        Munene, you can use this plugin. It's free:
                        SketchUp Extension Warehouse
                        Your library of custom third-party extensions created to optimize your SketchUp workflow.
                        (extensions.sketchup.com)
                        • V Offline
                          VallviFly
                          No lo entiendo, soy subscriptor premium y ¿aún así se tiene que pagar el Make Face? Algo debo de estar haciendo mal. ¿Me podéis ayudar por favor?
                          Gracias
                            Premium members get various discounts from our Shop, including some listed extensions' prices.
                            Most extensions are 'free'...
                            However, some developers have chosen to sell their extensions through their own sites - SketchUcation has no control over this.
                            This particular one was free, but its author decided to monetize it a while ago.
                            So if you want it you must pay for it, using the links provided...
                            *Los miembros Premium obtienen varios descuentos de nuestra Tienda, incluidos los precios de algunas extensiones enumeradas.
                            La mayoría de las extensiones son 'gratuitas'...
                            Sin embargo, algunos desarrolladores han optado por vender sus extensiones a través de sus propios sitios; SketchUcation no tiene control sobre esto.
                            Este en particular era gratuito, pero su autor decidió monetizarlo hace un tiempo.
                            Entonces, si lo desea, debe pagarlo, utilizando los enlaces provistos ...*
                            • G Offline
                              gruposolucoes
                              IT IS NO FREE, this sucker ask for money and put a password
                                Try to show some maturity and not resort to insulting.
                                If you want to fling shit try facebook, twitter etc...not here bud.
                                  Marquez24 Newcomers
                                  disculpen tengo un problema al querer usar el plugins me a aparece esto y no se como quitarlo o que correo poner
                                  TIGT 1 Reply Last reply Reply Quote 0
                                    TIG Moderator @Marquez24
                                    @Marquez24
                                    If you have purchased a license from S4u, you will have given your email address, and then got back a 'code'.
                                    Then to register the licensed extension you need to add the same email address and that code.
                                    After that the message should not reappear...
                                    • 3 / 3
