    [Plugin] S4u Make Face
    56 Posts 28 Posters 274.8k Views 28 Watching
      Tantema
      Hi Again,
      I repaired my .EXE file. I opened SU as an administrator and went to the Warehouse to install s4u Make Face. I checked to see if a library was required and there was no evidence of a s4u library in the warehouse or here on sketchucation. Then I closed SU and reopened and got this error
      https://3.bp.blogspot.com/-3VKWAn1FZ-c/W93lApG3KaI/AAAAAAAAAe4/y05FIkEx_lQOE5HPv4EWP-zaVYFP6NF9ACLcBGAs/s640/error.JPG
      I installed the RBZ file for Make Face from the Preferences Window, closed and reopened and got the same error. This was the same deal I went through with Fredo's extensions (with the exception being there I DID install Fredo's library first and got a whole bunch of errors) and why I've been transferring STL files out to other software. If someone can help me figure out why this is happening it would be greatly appreciated and it would greatly improve my workflow if I could stay in the same software.
        Tantema
        This may or may not be relevant but I downloaded LibFredo6 along with Joint Push Pull and Tools on Surface to see how my installation would respond to having a helper Library. Well... same as before I downloaded them all. I went to Preferences and installed each .RBZ file. Then I restarted SU as an administrator and I got this error
        https://4.bp.blogspot.com/-GF6GvE1sdcM/W93okuDbv4I/AAAAAAAAAfM/LsB9lxUam1s0a7KFiFT12UDaTFj6t2hdQCLcBGAs/s640/error%2B2.JPG
        So I have repaired my .EXE file and I've installed the helper library and I'm still getting errors. Does anyone know what exactly is causing these errors and how can I correct them?
          RoRay
          installed in Sketchup 2017 works fine, so far.
          Very simple tool and terrifically useful. thanks!
          • wahyuesgroupW Offline
            wahyuesgroup
            now this extension in Pro Version 😎 , nice Mr Vi
            • N Offline
              nikki8889
              Hello,
              I have sketchup 2017.
              I have downloaded the s4u makeface, but it does not work now. It gives the message that"s4u is not active"
              I checked the extension manager but it has a tick on the plugin.
                aadya 11
                hello i have installed it but it is asking for activation file i have sketchup 2019 pro mac version
                  Mercuriel
                  Wasn't this extension free since 2004 ? it asks for licence.
                  Now we've to buy this simple plugin, or code our own "makeface" and share it, or maybe this is a bug ? Anyone having explanation about the change reason ?
                    anoksha
                    its asking an activation code
                    • hdpvH Offline
                      hdpv
                      Trial and Purchase : https://www.sketchupforyou.com/purchase/s4u_makeface/
                      Suforyou
                      http://www.sketchupforyou.com
                        Munene
                        would you kindly consider making the make faces extensions free
                        • E Offline
                          Einstein
                          Munene, you can use this plugin. It's free:
                          SketchUp Extension Warehouse
                          Your library of custom third-party extensions created to optimize your SketchUp workflow.
                          (extensions.sketchup.com)
                          • V Offline
                            VallviFly
                            No lo entiendo, soy subscriptor premium y ¿aún así se tiene que pagar el Make Face? Algo debo de estar haciendo mal. ¿Me podéis ayudar por favor?
                            Gracias
                              Premium members get various discounts from our Shop, including some listed extensions' prices.
                              Most extensions are 'free'...
                              However, some developers have chosen to sell their extensions through their own sites - SketchUcation has no control over this.
                              This particular one was free, but its author decided to monetize it a while ago.
                              So if you want it you must pay for it, using the links provided...
                              *Los miembros Premium obtienen varios descuentos de nuestra Tienda, incluidos los precios de algunas extensiones enumeradas.
                              La mayoría de las extensiones son 'gratuitas'...
                              Sin embargo, algunos desarrolladores han optado por vender sus extensiones a través de sus propios sitios; SketchUcation no tiene control sobre esto.
                              Este en particular era gratuito, pero su autor decidió monetizarlo hace un tiempo.
                              Entonces, si lo desea, debe pagarlo, utilizando los enlaces provistos ...*
                                gruposolucoes
                                IT IS NO FREE, this sucker ask for money and put a password
                                  Try to show some maturity and not resort to insulting.
                                  If you want to fling shit try facebook, twitter etc...not here bud.
                                    Marquez24 Newcomers
                                    disculpen tengo un problema al querer usar el plugins me a aparece esto y no se como quitarlo o que correo poner
                                    TIGT 1 Reply Last reply Reply Quote 0
                                      TIG Moderator @Marquez24
                                      @Marquez24
                                      If you have purchased a license from S4u, you will have given your email address, and then got back a 'code'.
                                      Then to register the licensed extension you need to add the same email address and that code.
                                      After that the message should not reappear...
                                      • 3 / 3
