    Where are my material collections located?
    8 Posts 3 Posters 856 Views 3 Watching
    • ziiarZ Offline
      ziiar
      See image.
      I can make material collections with no problem but I can't find them in explorer.
      I have "show hidden files and folders" on, and I still see nothing.
      Any help would be appreciated, thanks.
      • BoxB Offline
        Are you looking in the right place? When you created the Test folder where did you create it. Click the button to create a new library and see where it went last. I think the default location is in My Documents.
        If you go, Window/Preferences/Files you can see where the materials are set to be stored and change it there.
        • ziiarZ Offline
          ziiar
          Yes, it was placed with all the other collections in the materials folder. In fact, if I try and save another collection I can see the "TEST" folder in the browse window (see image). For some reason the browse function can see something while windows explorer cannot.
          • BoxB Offline
            That path looks like you have created the folder within the Program Files section which requires all sorts of admin rights and security permissions. I can create a file in the same place called Test and I can see it in Explorer, but I have to jump through a few hoops to do it. It would be easier to create your collections directly in a less sensitive are of the file structure which is probably why they default to My Documents.
            Edit; I was doing this with SU2014, if you are using SU 8 then I don't know what the problem is because in SU8 I create a folder there and it works.
              Find the Materials folder within the SketchUp folder.
              With Admin abilities...
              Right-click > Context-menu > Properties > Security > Edit...
              Ensure every entry has FULL read/write permissions checked.
              Apply > OK
              The changes should ripple down to the contained subfolders/files.
              Restart SketchUp...
              Now can you see the TEST in the Materials Browser ?
              • ziiarZ Offline
                ziiar
                I still can't see it in explorer. It may be because I couldn't get the "Creator Owner" to get full permission. I check them but when I hit apply they clear away again.
                  You can't change that permission.
                  What did you get to change ?
                  Can you now save another collection into another folder in Materials ?
                  That TEST folder and its contents might not really be inside the Materials folder...
                  Your Windows might have put it into the VirtualStore to protect you from yourself.
                  Look in C:\Users\YourUserName\AppData\Local\VirtualStore
                  Is there any SketchUp and/or Materials stuff in there...
                  If so move it into the proper Materials folder...
                  Also double-check you are not using two different Materials folders in different SketchUp versions !
                  Your Preferences might be skewed and so start you off in the wrong location when making/saving ?
                  • ziiarZ Offline
                    ziiar
                    I got everything on except for the "Creator Owner"
                    But yes, it appears to have disappeared into "VirtualStore". Thanks!
