    [REQ] SU scatter
    51 Posts 20 Posters 30.6k Views 20 Watching
    • soloS Offline
      solo
      Here is a huge one, I'd expect this to be a commercial plugin if ever made and I'd be first in line to purchase.
      Below is a video of Carbon Scatter for Max, Maya and C4D, made by the Vue guys at E-on, I know that all those functionalities are impossible in SU but basic ones like scatter, paint and populate may well be right?
      These days most render engines use proxy's so we can now add millions of trees and grass patches, so a good way to distribute them is screaming to be found.
      Anyway, ponder it code geeks and watch the video below for inspiration.
      Thanks in advance.
      http://www.solos-art.com
        Transformer by Suforyou has yet some functions! πŸ˜‰
        and SU2components always by Suforyou can populate anything on any volumes'faces! β˜€
        (eg on a tree on sphere3D ) etc...
        • soloS Offline
          solo
          Pilou, not quite what I had in mind, I want scatter, spread, paint trees where I need them, heck even create a green wall if i please.
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            Here is a new plugin I'm working on, called Skatter, which is I think exactly what you're looking for.
            The goal is to be able to render hundreds of thousands of instances, but never generate them in SU, so it remains lightweight.
            As you can see in the video, Devin from Chaos Group already made it work in Vray. And Tomasz from Solid Iris is working to make it work in Thea. I'll soon get in touch with other render engines devs to see if they're interested.
            The developpement is only at a very early stage, in the final version there will be a lot more features and options.
              @JBB
              Easy setup a private beta forum here for you to get some testing going.
              Lots of devs use this system and we already have a pool of reliable testers assembled.
              Just throwing it out there if or when you need it.
                jiminy-billy-bob
                Rich, thanks for that!
                I won't need this until a more advance state, but I'll definitly get back to you in time πŸ˜‰
                • soloS Offline
                  solo
                  JBB
                  You been reading my mind, hell yeah, that is what I'm talking about, let me know when I can start testing. πŸ’š
                    jiminy-billy-bob
                    Well, for my rendering activity, I have similar needs as you πŸ˜‰
                    • PixeroP Offline
                      Pixero
                      Yes it looks very good. πŸ‘
                      I would also like to test this if possible.
                      One thing, I see you are using Vray proxys.
                      Please make it so it will work with other renderers too.
                        jiminy-billy-bob
                        You can feed in any component you want.
                        The one I use in the video is actually both a Vray proxy and a Thea Proxy. It will be part of a library shipped with the plugin, and it'll be a proxy for all render engines possible.
                        • andybotA Offline
                          andybot
                          that looks very nice! I've used Compo-spray for a long time, this looks to be a huge workflow changer!
                            jiminy-billy-bob
                            Here is how it performs with Thea 1.4. The render starts in a couple of seconds and the render itself took a few minutes with Presto.
                            http://i.imgur.com/Ynjb1yVl.jpg
                            Click for higher res.
                            This is a square surface roughly 130m*130m covered with dense grass.
                            475'000 instances of this grass patch:
                            http://i.imgur.com/ZEPgdGT.png
                            Btw, this is what the model looks like:
                            http://i.imgur.com/ePyEHiBl.png
                            Very lightweight, as all this vegetation is generated at render-time.
                            • massimoM Offline
                              massimo Moderator
                              πŸ‘ πŸ‘
                              • JQLJ Offline
                                JQL
                                Bah, too good to be true, you joker πŸ˜‰ πŸ˜„
                                www.casca.pt
                                Visit us on facebook!
                                  leminilab
                                  Yea, I think it's bluff too...
                                  Isn't it? πŸ˜•
                                  This looks too awesome to be true... Not in 2014... 😎
                                  • "Live every day as if it were your last and then some day you'll be right."
                                  • "ThomThom rules!!!"
                                    jiminy-billy-bob
                                    @leminilab said:
                                    Not in 2014... 😎
                                    You're right, it'll be available in 2015 πŸ˜‰
                                      bsfranza
                                      so.. whats it with su skatter - alive dead or what
                                        jiminy-billy-bob
                                        Very much alive, but not yet ready for public release.
                                        It'll come!
                                        • Bob JamesB Offline
                                          Bob James
                                          πŸŽ‰
                                            bsfranza
                                            thanks for the info though...
                                            will your skatter plugin work with any renderer availeable or is it somewhat bound to vray?
                                            • 1 / 3
