    [REQ] SU scatter
    51 Posts 20 Posters 34.8k Views 20 Watching
    • soloS
      Pilou, not quite what I had in mind, I want scatter, spread, paint trees where I need them, heck even create a green wall if i please.
      • jiminy-billy-bobJ
        jiminy-billy-bob
        Here is a new plugin I'm working on, called Skatter, which is I think exactly what you're looking for.
        The goal is to be able to render hundreds of thousands of instances, but never generate them in SU, so it remains lightweight.
        As you can see in the video, Devin from Chaos Group already made it work in Vray. And Tomasz from Solid Iris is working to make it work in Thea. I'll soon get in touch with other render engines devs to see if they're interested.
        The developpement is only at a very early stage, in the final version there will be a lot more features and options.
          @JBB
          Easy setup a private beta forum here for you to get some testing going.
          Lots of devs use this system and we already have a pool of reliable testers assembled.
          Just throwing it out there if or when you need it.
          • jiminy-billy-bobJ
            jiminy-billy-bob
            Rich, thanks for that!
            I won't need this until a more advance state, but I'll definitly get back to you in time πŸ˜‰
            • soloS
              JBB
              You been reading my mind, hell yeah, that is what I'm talking about, let me know when I can start testing. πŸ’š
              • jiminy-billy-bobJ
                jiminy-billy-bob
                Well, for my rendering activity, I have similar needs as you πŸ˜‰
                • PixeroP
                  Pixero
                  Yes it looks very good. πŸ‘
                  I would also like to test this if possible.
                  One thing, I see you are using Vray proxys.
                  Please make it so it will work with other renderers too.
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    You can feed in any component you want.
                    The one I use in the video is actually both a Vray proxy and a Thea Proxy. It will be part of a library shipped with the plugin, and it'll be a proxy for all render engines possible.
                    • andybotA
                      andybot
                      that looks very nice! I've used Compo-spray for a long time, this looks to be a huge workflow changer!
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        Here is how it performs with Thea 1.4. The render starts in a couple of seconds and the render itself took a few minutes with Presto.
                        http://i.imgur.com/Ynjb1yVl.jpg
                        Click for higher res.
                        This is a square surface roughly 130m*130m covered with dense grass.
                        475'000 instances of this grass patch:
                        http://i.imgur.com/ZEPgdGT.png
                        Btw, this is what the model looks like:
                        http://i.imgur.com/ePyEHiBl.png
                        Very lightweight, as all this vegetation is generated at render-time.
                        • massimoM
                          massimo Moderator
                          πŸ‘ πŸ‘
                          • JQLJ
                            JQL
                            Bah, too good to be true, you joker πŸ˜‰ πŸ˜„
                            www.casca.pt
                            Visit us on facebook!
                            • L
                              leminilab
                              Yea, I think it's bluff too...
                              Isn't it? πŸ˜•
                              This looks too awesome to be true... Not in 2014... 😎
                              • "Live every day as if it were your last and then some day you'll be right."
                              • "ThomThom rules!!!"
                              • jiminy-billy-bobJ
                                jiminy-billy-bob
                                @leminilab said:
                                Not in 2014... 😎
                                You're right, it'll be available in 2015 πŸ˜‰
                                • B
                                  bsfranza
                                  so.. whats it with su skatter - alive dead or what
                                  • jiminy-billy-bobJ
                                    jiminy-billy-bob
                                    Very much alive, but not yet ready for public release.
                                    It'll come!
                                    • Bob JamesB
                                      Bob James
                                      πŸŽ‰
                                      • B
                                        bsfranza
                                        thanks for the info though...
                                        will your skatter plugin work with any renderer availeable or is it somewhat bound to vray?
                                        • jiminy-billy-bobJ
                                          jiminy-billy-bob
                                          For now it works with Vray and Thea. I will work with other render engines developpers to make it work with their product. But for now I can't guaranty anything behond Vray and Thea.
                                          What engine would you like to use with Skatter?
                                          • duanekempD
                                            duanekemp
                                            Pete, just gave me the heads up on this post. Thank you Pete. This is exactly what I've been looking for. I've been manually building a proxy replace me model to solve this issue. But, JBB, if it's possible, I would love to test this as well. This looks so promising!
                                            Duane Kemp
                                            Kemp Productions
                                            Puidoux, Switzerland
                                            Gallery:
                                            https://duanekemp.artstation.com/
                                            • 1 / 3
