    How to Get the Texture file from a sketchup file??
    renderpluginsextensions
    4 Posts 3 Posters 542 Views 3 Watching
    • S
      sketchuh
      hi you all, I downloaded a sketchup model from 3d warehouse. the problem is when i render it in vray for sketchup. the texture couldn't be located. and I DON't have a jpg texture file. but the texture is showing in the sketchup scene. it just doesn't come out in the render.
      does this happen to anyone else. and how can i "extract" that img file from a sketchup file??!!
      if my question is not clear, please let me know!
      thanks.
      best regards
      note: if moderator thinks this should be in vray sub forum. please move it there, thanks.
      • massimoM
        massimo Moderator
        I know nothing about vray, anyway to "extract" a texture from a model in SU:
        -click on the "in model" button in the materials panel;
        -locate the material-->right click on it-->export texture image.
        • R
          rspierenburg
          You can also locate the .SKM file and rename it to .ZIP and extract it.
          Rob
          • S
            sketchuh
            thanks you all. i will try them. really useful tips!!
