    How did the great Alex Hogrefe do it ?
    Scheduled Pinned Locked Moved Post Processing
    39 Posts 3 Posters 25.5k Views 3 Watching
    • massimoM
      massimo Moderator
      The radius changes the position of the sun,
      Odd, that should not happen. Would you mind to post the scene?
      • olisheaO
        olishea
        larger radius does not change the sun position. Large radius = softer shadows. Small radius = sharper shadows. You must have soft shadows checked to see the effect of changing the sun's radius.
        I really love how this project is going, I find plan shadow studies very pleasing on the eye.
        oli
        • alexjoA
          alexjo
          Sure.
          Scene3.rar
          • massimoM
            massimo Moderator
            Ok, here is a try. Raw KT output.
            Of course, as I said before, you can change the softness of the shadows by changing the radius of the sun.
            scene_3.zip
            • alexjoA
              alexjo
              Legit amazing.
              • alexjoA
                alexjo
                Could you pleas tell me how you managed to achieve that clear white look ?
                & I see you have arranged the file, and added other elements.
                • massimoM
                  massimo Moderator
                  Well I've posted the scene, have a look at it. The render is a raw output of that scene, so just pick a clay render preset (I think I've used the 22 if I remember well, but more or less any clay preset will work) and render it. I added nothing, just tuned sun's multiplier and radius.
                  • massimoM
                    massimo Moderator
                    Oh and, if i remember well, also reduced the gamma from 1.5 to 1.2. Anyway you have the scene to look at.
                    • alexjoA
                      alexjo
                      Much appreciated, sir.
                      Have a nice day.
                      • massimoM
                        massimo Moderator
                        My pleasure. πŸ˜„
                        • massimoM
                          massimo Moderator
                          Here is another quick try using a HDRI for lighting. Perhaps more similar to the reference image you posted. The "direction" of light is less clear and you have less control on it and shadows are really soft, but the overall effect is pretty effective I believe. Only a slight levels correction in post pro.
                          • alexjoA
                            alexjo
                            Yes, this looks even better and less sharp.
                            Especially if you are going to place furniture and other data on the plans.
                            Could I please know what HDRI you used on this ?
                            • massimoM
                              massimo Moderator
                              You can find it here. Scroll down the page, it's called "van Kleef 3". I have made a black&white version of it. Also when you use a HDRI in KT is better to switch off "linear lightflow". In KT go to settings-->advanced-->scenes-->"you scene name"-->default global settings-->right click on the green thumbnail.
                              You may need to boost the HDRI intensity.
                              • alexjoA
                                alexjo
                                Thanks, but what does switching it off do ?
                                This is what I get :
                                http://i.minus.com/jbqupjvAdbexvy.jpg
                                • alexjoA
                                  alexjo
                                  Could you upload the last update you made please ?
                                  • massimoM
                                    massimo Moderator
                                    Basically it has to do with gamma setting of the HDRI: if HDRI has gamma correction set to 2.2 (most of them are that way) you should turn it off. If gamma is set to 1.0 the it has to be turned on. Just try to render with it turned on and off and see what happens.
                                    If you mean the scene with the HDRI then I can't because I deleted it. Anyway you have all the infos to reproduce it I guess. πŸ˜‰
                                    • alexjoA
                                      alexjo
                                      Oh, I see.
                                      Yepp, I'm still baffled about the sun jumping from its place when i change the radius tho.
                                      http://i.minus.com/joVOgGF5cV2bF.jpg
                                      • alexjoA
                                        alexjo
                                        I was also wondering, how yours looks more "Black & white" ?
                                        • massimoM
                                          massimo Moderator
                                          Be sure you don't have any color for sun/sky/HDRI. Also if you use the HDRI be sure to disable the sun.
                                          • 2 / 2
