    How did the great Alex Hogrefe do it ?
    Scheduled Pinned Locked Moved Post Processing
    39 Posts 3 Posters 24.6k Views 3 Watching
    • alexjoA Offline
      alexjo
      Oh oh, did my post get deleted lol
      • massimoM Offline
        massimo Moderator
        No post was deleted. You sent a PM to me. πŸ˜‰
        Here is what I replied: have you tried what I suggested? Tick "soft shadow" and increase the sun's radius?
        • alexjoA Offline
          alexjo
          Lmao, that was confusing.My bad.
          I actually did that right off the bat. But saw no difference. The radius changes the position of the sun, and it takes me a couple of minutes to get it back where i want it to be.
          • massimoM Offline
            massimo Moderator
            Odd, that should not happen. Would you mind to post the scene?
            • olisheaO Offline
              olishea
              larger radius does not change the sun position. Large radius = softer shadows. Small radius = sharper shadows. You must have soft shadows checked to see the effect of changing the sun's radius.
              I really love how this project is going, I find plan shadow studies very pleasing on the eye.
              oli
              • alexjoA Offline
                alexjo
                Sure.
                Scene3.rar
                • massimoM Offline
                  massimo Moderator
                  Ok, here is a try. Raw KT output.
                  Of course, as I said before, you can change the softness of the shadows by changing the radius of the sun.
                  scene_3.zip
                  • alexjoA Offline
                    alexjo
                    Legit amazing.
                    • alexjoA Offline
                      alexjo
                      Could you pleas tell me how you managed to achieve that clear white look ?
                      & I see you have arranged the file, and added other elements.
                      • massimoM Offline
                        massimo Moderator
                        Well I've posted the scene, have a look at it. The render is a raw output of that scene, so just pick a clay render preset (I think I've used the 22 if I remember well, but more or less any clay preset will work) and render it. I added nothing, just tuned sun's multiplier and radius.
                        • massimoM Offline
                          massimo Moderator
                          Oh and, if i remember well, also reduced the gamma from 1.5 to 1.2. Anyway you have the scene to look at.
                          • alexjoA Offline
                            alexjo
                            Much appreciated, sir.
                            Have a nice day.
                            • massimoM Offline
                              massimo Moderator
                              My pleasure. πŸ˜„
                              • massimoM Offline
                                massimo Moderator
                                Here is another quick try using a HDRI for lighting. Perhaps more similar to the reference image you posted. The "direction" of light is less clear and you have less control on it and shadows are really soft, but the overall effect is pretty effective I believe. Only a slight levels correction in post pro.
                                • alexjoA Offline
                                  alexjo
                                  Yes, this looks even better and less sharp.
                                  Especially if you are going to place furniture and other data on the plans.
                                  Could I please know what HDRI you used on this ?
                                  • massimoM Offline
                                    massimo Moderator
                                    You can find it here. Scroll down the page, it's called "van Kleef 3". I have made a black&white version of it. Also when you use a HDRI in KT is better to switch off "linear lightflow". In KT go to settings-->advanced-->scenes-->"you scene name"-->default global settings-->right click on the green thumbnail.
                                    You may need to boost the HDRI intensity.
                                    • alexjoA Offline
                                      alexjo
                                      Thanks, but what does switching it off do ?
                                      This is what I get :
                                      http://i.minus.com/jbqupjvAdbexvy.jpg
                                      • alexjoA Offline
                                        alexjo
                                        Could you upload the last update you made please ?
                                        • massimoM Offline
                                          massimo Moderator
                                          Basically it has to do with gamma setting of the HDRI: if HDRI has gamma correction set to 2.2 (most of them are that way) you should turn it off. If gamma is set to 1.0 the it has to be turned on. Just try to render with it turned on and off and see what happens.
                                          If you mean the scene with the HDRI then I can't because I deleted it. Anyway you have all the infos to reproduce it I guess. πŸ˜‰
                                          • alexjoA Offline
                                            alexjo
                                            Oh, I see.
                                            Yepp, I'm still baffled about the sun jumping from its place when i change the radius tho.
                                            http://i.minus.com/joVOgGF5cV2bF.jpg
                                            • 2 / 2
