    How did the great Alex Hogrefe do it ?
    Scheduled Pinned Locked Moved Post Processing
    39 Posts 3 Posters 24.7k Views 3 Watching
    • olisheaO
      olishea
      larger radius does not change the sun position. Large radius = softer shadows. Small radius = sharper shadows. You must have soft shadows checked to see the effect of changing the sun's radius.
      I really love how this project is going, I find plan shadow studies very pleasing on the eye.
      oli
      • alexjoA
        alexjo
        Sure.
        Scene3.rar
        • massimoM
          massimo Moderator
          Ok, here is a try. Raw KT output.
          Of course, as I said before, you can change the softness of the shadows by changing the radius of the sun.
          scene_3.zip
          • alexjoA
            alexjo
            Legit amazing.
            • alexjoA
              alexjo
              Could you pleas tell me how you managed to achieve that clear white look ?
              & I see you have arranged the file, and added other elements.
              • massimoM
                massimo Moderator
                Well I've posted the scene, have a look at it. The render is a raw output of that scene, so just pick a clay render preset (I think I've used the 22 if I remember well, but more or less any clay preset will work) and render it. I added nothing, just tuned sun's multiplier and radius.
                • massimoM
                  massimo Moderator
                  Oh and, if i remember well, also reduced the gamma from 1.5 to 1.2. Anyway you have the scene to look at.
                  • alexjoA
                    alexjo
                    Much appreciated, sir.
                    Have a nice day.
                    • massimoM
                      massimo Moderator
                      My pleasure. πŸ˜„
                      • massimoM
                        massimo Moderator
                        Here is another quick try using a HDRI for lighting. Perhaps more similar to the reference image you posted. The "direction" of light is less clear and you have less control on it and shadows are really soft, but the overall effect is pretty effective I believe. Only a slight levels correction in post pro.
                        • alexjoA
                          alexjo
                          Yes, this looks even better and less sharp.
                          Especially if you are going to place furniture and other data on the plans.
                          Could I please know what HDRI you used on this ?
                          • massimoM
                            massimo Moderator
                            You can find it here. Scroll down the page, it's called "van Kleef 3". I have made a black&white version of it. Also when you use a HDRI in KT is better to switch off "linear lightflow". In KT go to settings-->advanced-->scenes-->"you scene name"-->default global settings-->right click on the green thumbnail.
                            You may need to boost the HDRI intensity.
                            • alexjoA
                              alexjo
                              Thanks, but what does switching it off do ?
                              This is what I get :
                              http://i.minus.com/jbqupjvAdbexvy.jpg
                              • alexjoA
                                alexjo
                                Could you upload the last update you made please ?
                                • massimoM
                                  massimo Moderator
                                  Basically it has to do with gamma setting of the HDRI: if HDRI has gamma correction set to 2.2 (most of them are that way) you should turn it off. If gamma is set to 1.0 the it has to be turned on. Just try to render with it turned on and off and see what happens.
                                  If you mean the scene with the HDRI then I can't because I deleted it. Anyway you have all the infos to reproduce it I guess. πŸ˜‰
                                  • alexjoA
                                    alexjo
                                    Oh, I see.
                                    Yepp, I'm still baffled about the sun jumping from its place when i change the radius tho.
                                    http://i.minus.com/joVOgGF5cV2bF.jpg
                                    • alexjoA
                                      alexjo
                                      I was also wondering, how yours looks more "Black & white" ?
                                      • massimoM
                                        massimo Moderator
                                        Be sure you don't have any color for sun/sky/HDRI. Also if you use the HDRI be sure to disable the sun.
                                        • 2 / 2
