    How did the great Alex Hogrefe do it ?
    Scheduled Pinned Locked Moved Post Processing
    39 Posts 3 Posters 25.5k Views 3 Watching
    • massimoM
      massimo Moderator
      I think it's working now. Is this decent ?
      πŸ‘
      I do not like how unrealistic the shadows look, no matter how much I move the model around the sun
      If with "unrealistic" you mean "hard" then yes, tick "soft shadow" in the scene settings panel and play with sun's radius and multiplier.
      • massimoM
        massimo Moderator
        If you want to change the sun's position then..
        • alexjoA
          alexjo
          Ugh, thanks. That last tip was needed.
          Btw, the 4 Clay presets differ in quality and render time, right ?
          have you changed the gamma correction for your render sample ?
          • massimoM
            massimo Moderator
            Right.
            No. I didn't change anything.
            • alexjoA
              alexjo
              Hmm, best so far.
              http://i5.minus.com/jX0c9NPKRbu0D.jpg
              • massimoM
                massimo Moderator
                Well if you want to try to match the look of the pic you posted in your first post you have to use softer shadows I guess.
                • alexjoA
                  alexjo
                  Oh oh, did my post get deleted lol
                  • massimoM
                    massimo Moderator
                    No post was deleted. You sent a PM to me. πŸ˜‰
                    Here is what I replied: have you tried what I suggested? Tick "soft shadow" and increase the sun's radius?
                    • alexjoA
                      alexjo
                      Lmao, that was confusing.My bad.
                      I actually did that right off the bat. But saw no difference. The radius changes the position of the sun, and it takes me a couple of minutes to get it back where i want it to be.
                      • massimoM
                        massimo Moderator
                        Odd, that should not happen. Would you mind to post the scene?
                        • olisheaO
                          olishea
                          larger radius does not change the sun position. Large radius = softer shadows. Small radius = sharper shadows. You must have soft shadows checked to see the effect of changing the sun's radius.
                          I really love how this project is going, I find plan shadow studies very pleasing on the eye.
                          oli
                          • alexjoA
                            alexjo
                            Sure.
                            Scene3.rar
                            • massimoM
                              massimo Moderator
                              Ok, here is a try. Raw KT output.
                              Of course, as I said before, you can change the softness of the shadows by changing the radius of the sun.
                              scene_3.zip
                              • alexjoA
                                alexjo
                                Legit amazing.
                                • alexjoA
                                  alexjo
                                  Could you pleas tell me how you managed to achieve that clear white look ?
                                  & I see you have arranged the file, and added other elements.
                                  • massimoM
                                    massimo Moderator
                                    Well I've posted the scene, have a look at it. The render is a raw output of that scene, so just pick a clay render preset (I think I've used the 22 if I remember well, but more or less any clay preset will work) and render it. I added nothing, just tuned sun's multiplier and radius.
                                    • massimoM
                                      massimo Moderator
                                      Oh and, if i remember well, also reduced the gamma from 1.5 to 1.2. Anyway you have the scene to look at.
                                      • alexjoA
                                        alexjo
                                        Much appreciated, sir.
                                        Have a nice day.
                                        • massimoM
                                          massimo Moderator
                                          My pleasure. πŸ˜„
                                          • massimoM
                                            massimo Moderator
                                            Here is another quick try using a HDRI for lighting. Perhaps more similar to the reference image you posted. The "direction" of light is less clear and you have less control on it and shadows are really soft, but the overall effect is pretty effective I believe. Only a slight levels correction in post pro.
                                            • 2 / 2
