    Surface from Curved Contours Issue
    7 Posts 5 Posters 512 Views 5 Watching
    • U Offline
      unsuns
      Hello Eveyone !
      First of all I want to congragulate all of you for making this fantastic forum !
      I need your help to make a sofa with no angle in it following this steps :
      1- Make a cube
      2- Delete all faces, 2 coplanar horizontal edges and keep only 2 vertical edges.
      3- Transform it in a round angles polyline with an offset of 25 cm.
      4- Generate "skin" or "mesh" from this contour.
      This last step is an issue, I tried to do it with "Make faces", "Skin Soap and Bubble", "Curviloft" and "Add faces" but none of them works 😞.
      How could I do it ?
      Thank you for helping me !
      • massimoM Offline
        massimo Moderator
        Here is a way using curviloft plugin.
          Ferrari can maybe make this for very more complex forms! 😉
          Manual
          http://sketchucation.com/forums/download/file.php?id=58250
          • U Offline
            unsuns
            Thank you guys! That´s working !
              It's worth learning how to do this without the use of plugins, too.
                PushPull is always magic! ☀
                • JQLJ Offline
                  JQL
                  Pushpull and eraser tool from what you already have:
                  Best regards,
                  João
                  www.casca.pt
                  Visit us on facebook!
