    [Plugin] Skalp for SketchUp v2.0 (live section plugin)
    172 Posts 24 Posters 40.1k Views 24 Watching
      bjornkn
      @skalp said:
      Indeed we support sectioning nested objects, but we doesn't support nested section planes. We will investigated if we can introduce this in a next version.
      The Skalp Team
      I really hope you'll do that πŸ˜„
      Re nested objects, as the attached image shows, Skalp does not fully respect "local" section planes neither? It shows how it does add slices to solid objects/groups which are not cut by the SketchUp Section plane tool. The section plane is placed inside a group consisting of all the walls and windows only.
      • SkalpS Offline
        Skalp
        @bjornkn said:
        The Skalp Team
        At this we doesn't support sectionplanes nested into groups or components. But I'll report it as a feature request.
        The Skalp Team.
        Skalp
        http://www.skalp4sketchup.com
          bjornkn
          The Skalp Team.
          Thanks πŸ˜„
          I really think that supporting what SU supports re nesting etc would make Skalp a lot more useful.
          BTW, I just sent a bug report on this + another problem.
          Looks like the email you supplied, support@skalp4sketchup.be , doesn't work?
            Recipient address; support@skalp4sketchup.be
            Reason; Illegal host/domain name found
          I tried support@skalp4sketchup.com now instead. So far I haven't received any error messages from there.
          Regards
            bjornkn
            @skalp said:
            it is support@sklap4sketchup.com
            Really?
            I just got a reply/receipt from support@skalp4sketchup.com
            Haven't tried "sklap" yet though πŸ˜‰
            BTW, it would be nice if you translated also your 2 last menu sections, contact/resellers. Now part of it is in Dutch.
            It would also be nice if you made available a small text file or something with all changes/fixes in the last version(s), as well as known bugs and planned features?
            • SkalpS Offline
              Skalp
              @bjornkn said:
              The Skalp Team.
              Thanks πŸ˜„
              Regards
              it is support@skalp4sketchup.com
              Skalp
              • SkalpS Offline
                Skalp
                @bjornkn said:
                Really?
                There are 2 places where you can find all changes/fixes in the last version(s):
                • p45 in the getting started manual (http://download.skalp4sketchup.com/downloads/docs/getting_started.pdf)
                • Skalp.rb file in the plugin folder.
                The Skalp Team.
                Skalp
                • utilerU Offline
                  utiler
                  @skalp said:
                  @utiler said:
                  Hi Guys, just tried to import a CAD .lin file but I click on the link and nothing happens....
                  Any ideas?
                  What type of file do you try to load?
                  If you try to load pattern files, this should be a .pat file.
                  The Skalp Team
                  OK, thanks will try a .pat file. πŸ‘
                  Just Curious...
                  • utilerU Offline
                    utiler
                    @skalp said:
                    @utiler said:
                    Another question, I assume Skalp will only be viewed in Layout with either raster or hybrid mode; not vector. Is this correct?
                    If you like to see the textures, you should use raster or hybrid.
                    The patterns are raster in SketchUp and in Layout. Only when you use export to dxf, you get vector pattern hatches in autocad.
                    The Skalp Team.
                    Got it, thanks! πŸ‘
                    Just Curious...
                      bjornkn
                      The Skalp Team.
                      Thanks πŸ˜„
                      I wasn't aware of that the getting_started file was updated.
                      • SkalpS Offline
                        Skalp
                        The Skalp Team.
                        Thanks πŸ˜„
                        Skalp
                        • SkalpS Offline
                          Skalp
                          The Skalp Team.
                          Thanks πŸ˜„
                          You are right, this isn't the best place to put this info.
                          The getting started manual is updated regulary because it's still a document in progress. We are a two people company who work hard to make a very usefull plugin. We must divide our time in fixing bugs, golving support, implement new features, write a decent manual and making tutorial movies.... and we also need to do some marketing to earn some money to get time to make our plugin the best section plugin there is.
                          Bye the way this week there will be a very important update of our section algoritm! Skalp will section non solids much better and there is a lot more coming the next months...
                          The Skalp Team.
                          Skalp
                          • JClementsJ Offline
                            JClements
                            New updates:
                            Should the previous installation be deleted before installing the new or will the update write over the existing installation?
                            • FrederikF Offline
                              Frederik
                              @John...
                              It will all be taken care of automatically, when you update...
                              First it will uninstall the version you have and then SU will restart and you can install the new version subsequently... πŸ˜„
                              Cheers
                              Kim Frederik
                              • SkalpS Offline
                                Skalp
                                @jclements said:
                                New updates:
                                It depends. If the previous beta version wasn't expired and you clicked on the auto update feature. This previous version is uninstalled without removing your license file and you pattern files, sketchup is closed and you automatically go to the download page. Startup Sketchup again, install Skalp and you're up and running again.
                                When the beta version is expired you can install the new version right on top of the previous. You only need the restart SketchUp after installation. And you are also up and running again.
                                The Skalp Team.
                                Skalp
                                  cadmunkey
                                  This looks superb, it looks like it could save me a ton of time. Off to purchase now!
                                  • EdsonE Offline
                                    Edson
                                    @skalp said:
                                    @jclements said:
                                    New updates:
                                    The Skalp Team.
                                    what do you mean by "auto update feature" ? what am I missing here? I see no auto update feature anywhere in my mac version!
                                    another thing: I have installed updates in all sorts of ways and it always goes well. right now I downloaded the latest in the form of an .rbz file. just updated with sketchup on and it started working right away.
                                    http://www.mahfuz.arq.br
                                    • SkalpS Offline
                                      Skalp
                                      What to do if you have problems with installing Skalp 1.0 Beta 8:
                                      Due to the changing of the name and the path to meet the Sketchup Extension Warehouse guidelines we see on some computers trouble with the installation. You can do the following to fix this. Look at your plugin directory*. You wil see two directories one Skalp and the other Skalp_Skalp, there is also one file Skalp_Skalp.rb. If the file Skalp.rb is still there you may delete this file.
                                      You can now try to startup SketchUp and Skalp again. If this doesn't fix the problem feel free to contact us.
                                      *SketchUp plugin directory:
                                      Windows: C:\Users\YOUR USERNAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                                      Mac OS X: Open a new Finder window, press and hold the Option key on your keyboard, the click Go in the menu bar > Library > Application Support > SketchUp 2014 > SketchUp > Plugins
                                      The Skalp Team.
                                      Skalp
                                      • EdsonE Offline
                                        Edson
                                        [attachment=0:kiqvykc6]<!-- ia0 -->Schermafbeelding 2014-09-03 om 08.40.42.jpg<!-- ia0 -->[/attachment:kiqvykc6]
                                        The Skalp Team.
                                        the Skalp and the Skalp_Skalp folder contain absolutely the same stuff. can I delete the Skalp folder safely?
                                        • SkalpS Offline
                                          Skalp
                                          [attachment=0:3cxasb67]<!-- ia0 -->Schermafbeelding 2014-09-03 om 08.40.42.jpg<!-- ia0 -->[/attachment:3cxasb67]
                                          The Skalp Team.
                                          When the new version is up and running and you copied your custom made autocad pattern files to the new folder (only if you imported pattern files before) you can safely delete the old one.
                                          The Skalp Team.
                                          Skalp
                                          • SkalpS Offline
                                            Skalp
                                            Last week we released Skalp for SketchUp v1.0 beta 8 with an improved section algorithm.
                                            Skalp
                                            • 8
                                            • 9
                                            • 3 / 9
