    [Plugin] Skalp for SketchUp v2.0 (live section plugin)
    172 Posts 24 Posters 58.3k Views 24 Watching
    • SkalpS Offline
      Skalp
      @bjornkn said:
      I just bought it a little while ago, and it looks like it could be very useful.
      However, it is pretty beta'ish at the moment, and I'm really looking forward to the next release, be it beta or not. I suppose it's not much point writing a beta/bug report now that it expires within a few days?
      As it says that this current beta version expires 30 august, I hope there will be a new version available very soon?
      Please always write beta/bug reports to support@skalp4sketchup.be. This is important info for us. There will be a new beta this week.
      The Skalp Team.
      Skalp
      http://www.skalp4sketchup.com
        bjornkn
        The Skalp Team.
        I will do that after I get the new version, but currently I have to finish my current project.
        One question though:
        The manual says that Skalp supports nested groups/objects, but I can't really find if it is supposed to support "local sections"? That is one of the nice features of the SU sections that I can't get to work in Skalp.
        One example:
        I have a building with 4 floors, internal walls/doors and a lot of furniture.
        The building has walls/windows etc as subgroups, and furniture are grouped for each floor.
        Then it is all grouped into a single master group.
        What I want is to cut down the walls so that the interior is shown, complete with furniture. I do not want to slice through the furniture here..
        In SU I can apply a section to the external walls/windows only, or to the external/internal walls and windows, but leave all the furniture untouched. And I can apply sections to a single subobject far down the hierarchy, and to the entire scene, and have them all active at the same time.
        Such behaviour seems currently to be impossible in Skalp?
        The attachement shows 3 simultaneously active sections at different hierarchical levels.
        Would this be possible in Skalp?
        • utilerU Offline
          utiler
          Hi Guys, just tried to import a CAD .lin file but I click on the link and nothing happens....
          Any ideas?
          Just Curious...
          • utilerU Offline
            utiler
            Another question, I assume Skalp will only be viewed in Layout with either raster or hybrid mode; not vector. Is this correct?
            Just Curious...
            • SkalpS Offline
              Skalp
              Any ideas?
              What type of file do you try to load?
              If you try to load pattern files, this should be a .pat file.
              The Skalp Team
              Skalp
              • SkalpS Offline
                Skalp
                If you like to see the textures, you should use raster or hybrid.
                The patterns are raster in SketchUp and in Layout. Only when you use export to dxf, you get vector pattern hatches in autocad.
                The Skalp Team.
                Skalp
                • SkalpS Offline
                  Skalp
                  The Skalp Team.
                  One example:
                  Indeed we support sectioning nested objects, but we doesn't support nested section planes. We will investigated if we can introduce this in a next version.
                  The Skalp Team
                  Skalp
                    bjornkn
                    The Skalp Team
                    I really hope you'll do that πŸ˜„
                    Re nested objects, as the attached image shows, Skalp does not fully respect "local" section planes neither? It shows how it does add slices to solid objects/groups which are not cut by the SketchUp Section plane tool. The section plane is placed inside a group consisting of all the walls and windows only.
                    • SkalpS Offline
                      Skalp
                      @bjornkn said:
                      The Skalp Team
                      At this we doesn't support sectionplanes nested into groups or components. But I'll report it as a feature request.
                      The Skalp Team.
                      Skalp
                        bjornkn
                        The Skalp Team.
                        Thanks πŸ˜„
                        I really think that supporting what SU supports re nesting etc would make Skalp a lot more useful.
                        BTW, I just sent a bug report on this + another problem.
                        Looks like the email you supplied, support@skalp4sketchup.be , doesn't work?
                          Recipient address; support@skalp4sketchup.be
                          Reason; Illegal host/domain name found
                        I tried support@skalp4sketchup.com now instead. So far I haven't received any error messages from there.
                        Regards
                          bjornkn
                          @skalp said:
                          it is support@sklap4sketchup.com
                          Really?
                          I just got a reply/receipt from support@skalp4sketchup.com
                          Haven't tried "sklap" yet though πŸ˜‰
                          BTW, it would be nice if you translated also your 2 last menu sections, contact/resellers. Now part of it is in Dutch.
                          It would also be nice if you made available a small text file or something with all changes/fixes in the last version(s), as well as known bugs and planned features?
                          • SkalpS Offline
                            Skalp
                            @bjornkn said:
                            The Skalp Team.
                            Thanks πŸ˜„
                            Regards
                            it is support@skalp4sketchup.com
                            Skalp
                            • SkalpS Offline
                              Skalp
                              @bjornkn said:
                              Really?
                              There are 2 places where you can find all changes/fixes in the last version(s):
                              • p45 in the getting started manual (http://download.skalp4sketchup.com/downloads/docs/getting_started.pdf)
                              • Skalp.rb file in the plugin folder.
                              The Skalp Team.
                              Skalp
                              • utilerU Offline
                                utiler
                                @skalp said:
                                Any ideas?
                                The Skalp Team
                                OK, thanks will try a .pat file. πŸ‘
                                Just Curious...
                                • utilerU Offline
                                  utiler
                                  The Skalp Team.
                                  Got it, thanks! πŸ‘
                                  Just Curious...
                                    bjornkn
                                    The Skalp Team.
                                    Thanks πŸ˜„
                                    I wasn't aware of that the getting_started file was updated.
                                    • SkalpS Offline
                                      Skalp
                                      The Skalp Team.
                                      Thanks πŸ˜„
                                      Skalp
                                      • SkalpS Offline
                                        Skalp
                                        The Skalp Team.
                                        Thanks πŸ˜„
                                        You are right, this isn't the best place to put this info.
                                        The getting started manual is updated regulary because it's still a document in progress. We are a two people company who work hard to make a very usefull plugin. We must divide our time in fixing bugs, golving support, implement new features, write a decent manual and making tutorial movies.... and we also need to do some marketing to earn some money to get time to make our plugin the best section plugin there is.
                                        Bye the way this week there will be a very important update of our section algoritm! Skalp will section non solids much better and there is a lot more coming the next months...
                                        The Skalp Team.
                                        Skalp
                                        • JClementsJ Offline
                                          JClements
                                          New updates:
                                          Should the previous installation be deleted before installing the new or will the update write over the existing installation?
                                          • FrederikF Offline
                                            Frederik
                                            @John...
                                            It will all be taken care of automatically, when you update...
                                            First it will uninstall the version you have and then SU will restart and you can install the new version subsequently... πŸ˜„
                                            Cheers
                                            Kim Frederik
                                            • 3 / 9
