    [Plugin] Skalp for SketchUp v2.0 (live section plugin)
    172 Posts 24 Posters 58.3k Views 24 Watching
    • SkalpS Offline
      Skalp
      @bjornkn said:
      @skalp said:
      @bjornkn said:
      I just bought it a little while ago, and it looks like it could be very useful.
      However, it is pretty beta'ish at the moment, and I'm really looking forward to the next release, be it beta or not. I suppose it's not much point writing a beta/bug report now that it expires within a few days?
      As it says that this current beta version expires 30 august, I hope there will be a new version available very soon?
      Please always write beta/bug reports to support@skalp4sketchup.be. This is important info for us. There will be a new beta this week.
      The Skalp Team.
      I will do that after I get the new version, but currently I have to finish my current project.
      One question though:
      The manual says that Skalp supports nested groups/objects, but I can't really find if it is supposed to support "local sections"? That is one of the nice features of the SU sections that I can't get to work in Skalp.
      One example:
      I have a building with 4 floors, internal walls/doors and a lot of furniture.
      The building has walls/windows etc as subgroups, and furniture are grouped for each floor.
      Then it is all grouped into a single master group.
      What I want is to cut down the walls so that the interior is shown, complete with furniture. I do not want to slice through the furniture here..
      In SU I can apply a section to the external walls/windows only, or to the external/internal walls and windows, but leave all the furniture untouched. And I can apply sections to a single subobject far down the hierarchy, and to the entire scene, and have them all active at the same time.
      Such behaviour seems currently to be impossible in Skalp?
      The attachement shows 3 simultaneously active sections at different hierarchical levels.
      Would this be possible in Skalp?
      Indeed we support sectioning nested objects, but we doesn't support nested section planes. We will investigated if we can introduce this in a next version.
      The Skalp Team
      Skalp
      http://www.skalp4sketchup.com
        bjornkn
        The Skalp Team
        I really hope you'll do that πŸ˜„
        Re nested objects, as the attached image shows, Skalp does not fully respect "local" section planes neither? It shows how it does add slices to solid objects/groups which are not cut by the SketchUp Section plane tool. The section plane is placed inside a group consisting of all the walls and windows only.
        • SkalpS Offline
          Skalp
          @bjornkn said:
          The Skalp Team
          At this we doesn't support sectionplanes nested into groups or components. But I'll report it as a feature request.
          The Skalp Team.
          Skalp
            bjornkn
            The Skalp Team.
            Thanks πŸ˜„
            I really think that supporting what SU supports re nesting etc would make Skalp a lot more useful.
            BTW, I just sent a bug report on this + another problem.
            Looks like the email you supplied, support@skalp4sketchup.be , doesn't work?
              Recipient address; support@skalp4sketchup.be
              Reason; Illegal host/domain name found
            I tried support@skalp4sketchup.com now instead. So far I haven't received any error messages from there.
            Regards
              bjornkn
              @skalp said:
              it is support@sklap4sketchup.com
              Really?
              I just got a reply/receipt from support@skalp4sketchup.com
              Haven't tried "sklap" yet though πŸ˜‰
              BTW, it would be nice if you translated also your 2 last menu sections, contact/resellers. Now part of it is in Dutch.
              It would also be nice if you made available a small text file or something with all changes/fixes in the last version(s), as well as known bugs and planned features?
              • SkalpS Offline
                Skalp
                @bjornkn said:
                The Skalp Team.
                Thanks πŸ˜„
                Regards
                it is support@skalp4sketchup.com
                Skalp
                • SkalpS Offline
                  Skalp
                  @bjornkn said:
                  Really?
                  There are 2 places where you can find all changes/fixes in the last version(s):
                  • p45 in the getting started manual (http://download.skalp4sketchup.com/downloads/docs/getting_started.pdf)
                  • Skalp.rb file in the plugin folder.
                  The Skalp Team.
                  Skalp
                  • utilerU Offline
                    utiler
                    @skalp said:
                    @utiler said:
                    Hi Guys, just tried to import a CAD .lin file but I click on the link and nothing happens....
                    Any ideas?
                    What type of file do you try to load?
                    If you try to load pattern files, this should be a .pat file.
                    The Skalp Team
                    OK, thanks will try a .pat file. πŸ‘
                    Just Curious...
                    • utilerU Offline
                      utiler
                      @skalp said:
                      @utiler said:
                      Another question, I assume Skalp will only be viewed in Layout with either raster or hybrid mode; not vector. Is this correct?
                      If you like to see the textures, you should use raster or hybrid.
                      The patterns are raster in SketchUp and in Layout. Only when you use export to dxf, you get vector pattern hatches in autocad.
                      The Skalp Team.
                      Got it, thanks! πŸ‘
                      Just Curious...
                        bjornkn
                        The Skalp Team.
                        Thanks πŸ˜„
                        I wasn't aware of that the getting_started file was updated.
                        • SkalpS Offline
                          Skalp
                          The Skalp Team.
                          Thanks πŸ˜„
                          Skalp
                          • SkalpS Offline
                            Skalp
                            The Skalp Team.
                            Thanks πŸ˜„
                            You are right, this isn't the best place to put this info.
                            The getting started manual is updated regulary because it's still a document in progress. We are a two people company who work hard to make a very usefull plugin. We must divide our time in fixing bugs, golving support, implement new features, write a decent manual and making tutorial movies.... and we also need to do some marketing to earn some money to get time to make our plugin the best section plugin there is.
                            Bye the way this week there will be a very important update of our section algoritm! Skalp will section non solids much better and there is a lot more coming the next months...
                            The Skalp Team.
                            Skalp
                            • JClementsJ Offline
                              JClements
                              New updates:
                              Should the previous installation be deleted before installing the new or will the update write over the existing installation?
                              • FrederikF Offline
                                Frederik
                                @John...
                                It will all be taken care of automatically, when you update...
                                First it will uninstall the version you have and then SU will restart and you can install the new version subsequently... πŸ˜„
                                Cheers
                                Kim Frederik
                                • SkalpS Offline
                                  Skalp
                                  @jclements said:
                                  New updates:
                                  It depends. If the previous beta version wasn't expired and you clicked on the auto update feature. This previous version is uninstalled without removing your license file and you pattern files, sketchup is closed and you automatically go to the download page. Startup Sketchup again, install Skalp and you're up and running again.
                                  When the beta version is expired you can install the new version right on top of the previous. You only need the restart SketchUp after installation. And you are also up and running again.
                                  The Skalp Team.
                                  Skalp
                                    cadmunkey
                                    This looks superb, it looks like it could save me a ton of time. Off to purchase now!
                                    • EdsonE Offline
                                      Edson
                                      @skalp said:
                                      @jclements said:
                                      New updates:
                                      The Skalp Team.
                                      what do you mean by "auto update feature" ? what am I missing here? I see no auto update feature anywhere in my mac version!
                                      another thing: I have installed updates in all sorts of ways and it always goes well. right now I downloaded the latest in the form of an .rbz file. just updated with sketchup on and it started working right away.
                                      http://www.mahfuz.arq.br
                                      • SkalpS Offline
                                        Skalp
                                        What to do if you have problems with installing Skalp 1.0 Beta 8:
                                        Due to the changing of the name and the path to meet the Sketchup Extension Warehouse guidelines we see on some computers trouble with the installation. You can do the following to fix this. Look at your plugin directory*. You wil see two directories one Skalp and the other Skalp_Skalp, there is also one file Skalp_Skalp.rb. If the file Skalp.rb is still there you may delete this file.
                                        You can now try to startup SketchUp and Skalp again. If this doesn't fix the problem feel free to contact us.
                                        *SketchUp plugin directory:
                                        Windows: C:\Users\YOUR USERNAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                                        Mac OS X: Open a new Finder window, press and hold the Option key on your keyboard, the click Go in the menu bar > Library > Application Support > SketchUp 2014 > SketchUp > Plugins
                                        The Skalp Team.
                                        Skalp
                                        • EdsonE Offline
                                          Edson
                                          [attachment=0:kiqvykc6]<!-- ia0 -->Schermafbeelding 2014-09-03 om 08.40.42.jpg<!-- ia0 -->[/attachment:kiqvykc6]
                                          The Skalp Team.
                                          the Skalp and the Skalp_Skalp folder contain absolutely the same stuff. can I delete the Skalp folder safely?
                                          • SkalpS Offline
                                            Skalp
                                            [attachment=0:3cxasb67]<!-- ia0 -->Schermafbeelding 2014-09-03 om 08.40.42.jpg<!-- ia0 -->[/attachment:3cxasb67]
                                            The Skalp Team.
                                            When the new version is up and running and you copied your custom made autocad pattern files to the new folder (only if you imported pattern files before) you can safely delete the old one.
                                            The Skalp Team.
                                            Skalp
                                            • 3 / 9
