    [Plugin] Skalp for SketchUp v2.0 (live section plugin)
    172 Posts 24 Posters 64.1k Views 24 Watching
    • utilerU
      utiler
      Hi Guys, just tried to import a CAD .lin file but I click on the link and nothing happens....
      Any ideas?
      Just Curious...
      • utilerU
        utiler
        Another question, I assume Skalp will only be viewed in Layout with either raster or hybrid mode; not vector. Is this correct?
        Just Curious...
        • SkalpS
          Skalp
          Any ideas?
          What type of file do you try to load?
          If you try to load pattern files, this should be a .pat file.
          The Skalp Team
          Skalp
          http://www.skalp4sketchup.com
          • SkalpS
            Skalp
            If you like to see the textures, you should use raster or hybrid.
            The patterns are raster in SketchUp and in Layout. Only when you use export to dxf, you get vector pattern hatches in autocad.
            The Skalp Team.
            Skalp
            • SkalpS
              Skalp
              @bjornkn said:
              @skalp said:
              @bjornkn said:
              I just bought it a little while ago, and it looks like it could be very useful.
              However, it is pretty beta'ish at the moment, and I'm really looking forward to the next release, be it beta or not. I suppose it's not much point writing a beta/bug report now that it expires within a few days?
              As it says that this current beta version expires 30 august, I hope there will be a new version available very soon?
              Please always write beta/bug reports to support@skalp4sketchup.be. This is important info for us. There will be a new beta this week.
              The Skalp Team.
              I will do that after I get the new version, but currently I have to finish my current project.
              One question though:
              The manual says that Skalp supports nested groups/objects, but I can't really find if it is supposed to support "local sections"? That is one of the nice features of the SU sections that I can't get to work in Skalp.
              One example:
              I have a building with 4 floors, internal walls/doors and a lot of furniture.
              The building has walls/windows etc as subgroups, and furniture are grouped for each floor.
              Then it is all grouped into a single master group.
              What I want is to cut down the walls so that the interior is shown, complete with furniture. I do not want to slice through the furniture here..
              In SU I can apply a section to the external walls/windows only, or to the external/internal walls and windows, but leave all the furniture untouched. And I can apply sections to a single subobject far down the hierarchy, and to the entire scene, and have them all active at the same time.
              Such behaviour seems currently to be impossible in Skalp?
              The attachement shows 3 simultaneously active sections at different hierarchical levels.
              Would this be possible in Skalp?
              Indeed we support sectioning nested objects, but we doesn't support nested section planes. We will investigated if we can introduce this in a next version.
              The Skalp Team
              Skalp
              • B
                bjornkn
                The Skalp Team
                I really hope you'll do that πŸ˜„
                Re nested objects, as the attached image shows, Skalp does not fully respect "local" section planes neither? It shows how it does add slices to solid objects/groups which are not cut by the SketchUp Section plane tool. The section plane is placed inside a group consisting of all the walls and windows only.
                • SkalpS
                  Skalp
                  @bjornkn said:
                  The Skalp Team
                  At this we doesn't support sectionplanes nested into groups or components. But I'll report it as a feature request.
                  The Skalp Team.
                  Skalp
                  • B
                    bjornkn
                    The Skalp Team.
                    Thanks πŸ˜„
                    I really think that supporting what SU supports re nesting etc would make Skalp a lot more useful.
                    BTW, I just sent a bug report on this + another problem.
                    Looks like the email you supplied, support@skalp4sketchup.be , doesn't work?
                      Recipient address; support@skalp4sketchup.be
                      Reason; Illegal host/domain name found
                    I tried support@skalp4sketchup.com now instead. So far I haven't received any error messages from there.
                    Regards
                    • B
                      bjornkn
                      @skalp said:
                      it is support@sklap4sketchup.com
                      Really?
                      I just got a reply/receipt from support@skalp4sketchup.com
                      Haven't tried "sklap" yet though πŸ˜‰
                      BTW, it would be nice if you translated also your 2 last menu sections, contact/resellers. Now part of it is in Dutch.
                      It would also be nice if you made available a small text file or something with all changes/fixes in the last version(s), as well as known bugs and planned features?
                      • SkalpS
                        Skalp
                        @bjornkn said:
                        The Skalp Team.
                        Thanks πŸ˜„
                        Regards
                        it is support@skalp4sketchup.com
                        Skalp
                        • SkalpS
                          Skalp
                          @bjornkn said:
                          Really?
                          There are 2 places where you can find all changes/fixes in the last version(s):
                          • p45 in the getting started manual (http://download.skalp4sketchup.com/downloads/docs/getting_started.pdf)
                          • Skalp.rb file in the plugin folder.
                          The Skalp Team.
                          Skalp
                          • utilerU
                            utiler
                            @skalp said:
                            Any ideas?
                            The Skalp Team
                            OK, thanks will try a .pat file. πŸ‘
                            Just Curious...
                            • utilerU
                              utiler
                              The Skalp Team.
                              Got it, thanks! πŸ‘
                              Just Curious...
                              • B
                                bjornkn
                                The Skalp Team.
                                Thanks πŸ˜„
                                I wasn't aware of that the getting_started file was updated.
                                • SkalpS
                                  Skalp
                                  The Skalp Team.
                                  Thanks πŸ˜„
                                  Skalp
                                  • SkalpS
                                    Skalp
                                    The Skalp Team.
                                    Thanks πŸ˜„
                                    You are right, this isn't the best place to put this info.
                                    The getting started manual is updated regulary because it's still a document in progress. We are a two people company who work hard to make a very usefull plugin. We must divide our time in fixing bugs, golving support, implement new features, write a decent manual and making tutorial movies.... and we also need to do some marketing to earn some money to get time to make our plugin the best section plugin there is.
                                    Bye the way this week there will be a very important update of our section algoritm! Skalp will section non solids much better and there is a lot more coming the next months...
                                    The Skalp Team.
                                    Skalp
                                    • JClementsJ
                                      JClements
                                      New updates:
                                      Should the previous installation be deleted before installing the new or will the update write over the existing installation?
                                      • FrederikF
                                        Frederik
                                        @John...
                                        It will all be taken care of automatically, when you update...
                                        First it will uninstall the version you have and then SU will restart and you can install the new version subsequently... πŸ˜„
                                        Cheers
                                        Kim Frederik
                                        • SkalpS
                                          Skalp
                                          @jclements said:
                                          New updates:
                                          It depends. If the previous beta version wasn't expired and you clicked on the auto update feature. This previous version is uninstalled without removing your license file and you pattern files, sketchup is closed and you automatically go to the download page. Startup Sketchup again, install Skalp and you're up and running again.
                                          When the beta version is expired you can install the new version right on top of the previous. You only need the restart SketchUp after installation. And you are also up and running again.
                                          The Skalp Team.
                                          Skalp
                                          • C
                                            cadmunkey
                                            This looks superb, it looks like it could save me a ton of time. Off to purchase now!
                                            • 3 / 9
