    Projected objects pt2
    3 Posts 3 Posters 282 Views 3 Watching
      jamie7991
      Hi folks
      Doing this research for work is doing my head in.
      I am trying to apply a livery to a car. I have the car imported from the warehouse and would like to create an outline from the sides and front, enough so I have the car outline, doors, windows and wheel rims etc. Basically, I want a 2D representation of each side projected onto a rectangle so I can do the livery design. The design is basic, so I do not need a graphics editor for it.
      I tried draping the car onto the rectangle but it was not for having it. Any ideas?
      J
      • TIGT Online
        Look for my Plugins like 'Project to Plane' and 'Silhouette'...
        Note it also needs my 'WorkPlane' tool installed...
        • xiombargX Offline
          xiombarg
          Here's a solution that I tried out and it works relatively well.
          1- Ungroup everything in your car model.
          2- Make a copy of the car (if you only need two views, front and side views)
          3- Viewing each copy separately in each orthographic view of front and side, use the Artisan knife tool to slice the car in half. Delete the back half of the car in the one model and a side of the car in the other (the idea here is to get rid of any pieces that when flattened into a pancake we do not want to see IE the back of the car...).
          4- Use Vertex Tools or any scaling tool that allows you scale an object to absolute flat zero and flatten each instance of the car pieces to the appropriate plane.
          Essentially the idea here is to crunch the car by scaling into a single plane but getting rid of the details of the opposite sides when merged together. For your side view you might be able to just scale the vehicle without cutting it in half, but you might end up extra unwanted polygons depending on how well the two sides of the car mirror each other.
