    Darker image after save
    renderpluginsextensions
    3 Posts 2 Posters 419 Views 2 Watching
    • K Offline
      Kontroliora
      I need your help. The problem is that:
      In frame buffer the render look good whit smooth shadows but when i save it (jpeg,png,...)
      I see that the output render is a little bit darker 5-10% from the image from the frame buffer. How can reduce this difference.
      Thanks in advance.
      • TedVitale_CGT Offline
        TedVitale_CG
        Without a scene or examples of the problem its very hard to help you. In the frame buffer, are you making any changes to the color profiles before you save? Have you tried saving as a targa, tiff, or exr to see if the different compression outputs have something to do with it?
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
        • K Offline
          Kontroliora
          Problem solved! Thanks TedVitale_CG
          Whit tiff is ok
