Darker image after save
I need your help. The problem is that:
In frame buffer the render look good whit smooth shadows but when i save it (jpeg,png,...)
I see that the output render is a little bit darker 5-10% from the image from the frame buffer. How can reduce this difference.
Thanks in advance. -
Without a scene or examples of the problem its very hard to help you. In the frame buffer, are you making any changes to the color profiles before you save? Have you tried saving as a targa, tiff, or exr to see if the different compression outputs have something to do with it?
Problem solved! Thanks TedVitale_CG
Whit tiff is ok
