π Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
Purge deleting vray textures
When I purge my scene, I lose my textures on proxy models. Does anyone know a work around for this.
Sketchup 2013 + Vray 2.0
You should purge material only from Vray's material editor.
Or you could apply the materials you don't want to delete on some geometry somewhere. -
Or get/install my 'Purge All' plugin...
Then you can Purge and choose to exclude Materials from the operation.
http://sketchucation.com/pluginstore?pln=PurgeAll
That way you keep the SKP trim, but leave Materials unchanged... -
Thank you both.
Already have your plugin installed TIG, very useful plugin- did not realise you could specify not to purge materials.
iminy-billy-bob - Thank you, applying the material, makes perfect sense now.
