    Need to change slope on complex object
    13 Posts 5 Posters 921 Views 5 Watching
      catwoman
      Hi, folks!
      Here I am, years later, still in the Newbie forum! Well, I don't use SU as often as you do. But now I've run into a problem, and need help.
      I'm building a U-shaped ramp for disabled access (in SU -- I'm actually making an existing ramp ADA-compliant), and it has a fence-like banister with lots of vertical members along with the handicapped handrails (running separately along the inside of the "fence"). The fence-like sections consist of an upper and lower horizontal 1" x 2" (in section) face that is extruded along the length of the fence segment, and the vertical 1" x 1" faces, extruded vertically, in-between them. Essentially a ladder on its side, with the rungs spaced 4" o.c. They run between vertical 4 x 4 columns - but that's not important. I created the first segment along the edge of the ramp so as to have the banister-fence parallel to its slope. (So what I refer to as "horizontal" isn't -- it's slightly angled.)
      I've copied and mirrored and placed them, but when I got to the other side of the ramp (the other "leg" of the "U"), I found I had a slightly different slope. The fence segments are both components or groups. Now I want to angle a segment more, to increase the slope. But that seems to be impossible with a component or group made up of many pieces, and if I explode them and try to raise one side (and what is one side, anyway, when you have so many parts!), they won't move together.
      How can I accomplish this without redrawing the entire fence piece along the higher sloped ramp? How would you handle this? I'm stumped.
      Thanks in advance!
      Gigi
        Please put an image and SKP (V) of the critic part! 😄
          catwoman
          OK, but not sure I'll be able to do the .skp file. I will try.
          ![Note the bottom of banister on the higher "leg" of the ramp.](/uploads/imported_attachments/TEfG_pember-ramp-redesign-01-slope-problem.jpg "Note the bottom of banister on the higher "leg" of the ramp.")
            catwoman
            It's not working with the .skp file. I probably don't know how to do it. After waiting and waiting, I get the message that "No data was sent," (or... found, or received, or something like that).
              How about using Planar Shearing from FredoScale?
                catwoman
                Thank you, Dave -- I have just finally successfully found and installed FredoScale. From your example, it certainly does look exactly like what I need. Thank you so much! Gigi
                  catwoman
                  May I ask (anyone) how the FredoScale Plane Shear tool is used? I downloaded the .pdf user manual but it only covers the FredoScale part -- this is a set of plug-ins and the other ones didn't get a mention. So I looked on his page, searched on SketchUcation, and on google, and can't find any discussion or instructions anywhere.
                  Thanks for helping!
                  Gigi
                    Gigi, all I did was select the railing component (which contained the rails and the spindles) and then the Shear tool. I clicked on a handle in the middle of the top edge at one end and dragged it upward. It's a little like working the Scale tool.
                      catwoman
                      I seem to get a rotation tool, so maybe I'm clicking on the wrong one. The one I use has a set of red arrows (one pointing up, one down), and it says "Planar shearing by selection of plane and angle" when you hover over it. Should I be using another one?
                      What you describe is exactly what I want to be doing, because I have a point marked to which I want to raise that one side!
                      • massimoM Offline
                        massimo Moderator
                          I used the blue one. See the upper left corner of the screen shot.
                          Beaten to the punch. 😉
                            catwoman
                            Thank you, thank you, both of you! Thank you Dave for turning me on to this plethora of plug-ins! They will surely make much work simpler for me for a very long time. And thank you, Massimo, for clarifying that detail that had me scratching my head.
                            Gigi
                            • mitcorbM Offline
                              mitcorb
                              Just some words of caution:
                              IF you are unable to widen the ramp surface to extend under the ballustrade sufficiently, a sharp eyed inspector may say you need some kind of "kickboard" or curb for compliance. This might be related to use of a cane or crutches and the likelihood of these slipping off the ramp surface. Then again, this may not be a problem in your particular case.
                              Excessive rail extension at the bottom of the ramp can also be a hazard under some circumstances.
