    Plugin to soften / divide corners?
    10 Posts 6 Posters 699 Views 6 Watching
      Lz
      Hello. I need a few tips. Is there some plugin that lets you 'soften' corners, as in the following:
      http://i1308.photobucket.com/albums/s613/Lzoli18/Snap1_zps9decbad6.png
      Also, I would like to know how I can force the program to draw even (equally distant between two points) lines on face corners, like the one seen here:
      http://i1308.photobucket.com/albums/s613/Lzoli18/Snap4_zpse5143f93.png
      Sometimes sketchup will refuse to draw these lines and its fairly annoying. And before I forget - is there a way to 'tie' lines in together (an option that is opposite to the 'explode' command)? I have sketchup 8. Thanks.
      • olisheaO Offline
        olishea
        Weld plugin.
        oli
          have you an skp of that ?
          Save in V6 for a more large audience! πŸ€“
          • massimoM Offline
            massimo Moderator
            Don't cheat Pilou, everyone has seen that now you are playing with Sophie... 😲
              Lz
              Thanks for the advice.
              Regarding the 'On Edge' pink lines. Sometimes when I try to draw them, SU simply won't 'snap' as it should. The line does not turn pink. Maybe there's a key shortcut to force SU to create such a line? Just curious, it isn't a huge problem.
                @Massimo
                Yes, but on my V6 I have thousand of plugins installed! πŸ€“
                So...more easy to aswer and test! And volumes can be reloaded in any versions! 😎
                  @Pilou
                  Cavemen built houses for a reason.
                  Join us in the 21st Century
                  • soloS Offline
                    solo
                    @rich o brien said:
                    @Pilou
                    He has too much furniture (plugins) in his old house, too much effort to move.
                    http://www.solos-art.com
                      @Rich
                      But that is not marvelous to have both ? 😲
                      http://www.cagou.com/blog/wp-content/uploads/2012/07/jeunes-et-vieux.jpg
                        Sure! πŸ‘
                        And curiously I had belived that Artisan can make the corners but no! 😒
                        May round corner By Fredo6?
                        So cavern modern houses! πŸ˜„
                        And no jealousy! πŸ˜†
