Plugin to soften / divide corners?
Hello. I need a few tips. Is there some plugin that lets you 'soften' corners, as in the following:
Also, I would like to know how I can force the program to draw even (equally distant between two points) lines on face corners, like the one seen here:
Sometimes sketchup will refuse to draw these lines and its fairly annoying. And before I forget - is there a way to 'tie' lines in together (an option that is opposite to the 'explode' command)? I have sketchup 8. Thanks.
Weld plugin.
have you an skp of that ?
Save in V6 for a more large audience! -
Save in V6 for a more large audience!Don't cheat Pilou, everyone has seen that now you are playing with Sophie...
Thanks for the advice.
Regarding the 'On Edge' pink lines. Sometimes when I try to draw them, SU simply won't 'snap' as it should. The line does not turn pink. Maybe there's a key shortcut to force SU to create such a line? Just curious, it isn't a huge problem.
@Massimo
Yes, but on my V6 I have thousand of plugins installed!So...more easy to aswer and test! And volumes can be reloaded in any versions!
@Rich
But that is not marvelous to have both ? -
Sure!
And curiously I had belived that Artisan can make the corners but no!
May round corner By Fredo6?So cavern modern houses!
And no jealousy!
