    Creating Proxies for Vray( Vrmesh and Vismat)
    renderpluginsextensions
    3 Posts 3 Posters 1.9k Views 3 Watching
      Acheampong
      When creating lets say a proxy tree, is there a way by which I can create a vismat file to go with my Vrmesh file so that when I import my Vrmesh back to skecthup,I can equally go to the Material Editor and Import my Vismat file (containing material information for leaves,bark etc..) so that the proxy IDs get updated with the material required automatically.
      • andybotA Offline
        andybot
        If you are using the current service pack of vray for SU 2.0, the proxy export should be creating a component file that has all the vray materials in it. You shouldn't need to import vismats separately.
          sketchuh
          The weird thing happened that my vary proxy item turn transparent in the render image.
          I though there is no way to edit the proxy item in the vray material editor. Since the proxy is just fragmented polygon floating in air. It will be nice if it's true.
