    OpenGL Driver
    14 Posts 6 Posters 2.6k Views 6 Watching
      matt.gordon320
      Hi guys,
      I just upgraded to SketchUp 2014, and I have a quick question. It loaded by default with OpenGL driver #(either 197 or 397), and it looked absolutely fantastic, worked great. I normally switch drivers to #40 (Anti-alias 4x) on previous versions because that looked and worked mostly smoothly. I did this, and now the previous driver is no longer available. Any thoughts on why and how the option for that driver would disappear after changing it, and is there any way to get it back? I've already made sure that all my videos drivers and everything are up to date. Is my best course just to uninstall and re-install?
      This should have one more option, #197 or #397. I can't remember.
      Thanks!
      Matt
      • Rich O BrienR Online
        There's a ruby snippet somewhere that resets the opengl setting that SU declares on first launch.
        But I can't find it...where's cotty when you need him?
        • cottyC Offline
          cotty
          Im here, but I dont know the snippet 😳
          my SketchUp gallery
            OK....
            then we need TIG or Thomthom to bail us out.
            I know for a fact that there's a snippet for this.
              matt.gordon320
              Thanks for the help guys! I'll keep an eye out for TIG or Thomthom
              • KrisidiousK Offline
                Krisidious
                OpenGL settings on the Mac OS X version of SketchUp are different than on Windows, but you should be able to get something nice to look at on either platform. It looks to me a little like you're not running your display at its native resolution, but I can't be sure. Typically, the Mac OS picks a pretty reasonable setting for you- you may (however) want to try forcing FSAA (Full Screen Anti-Aliasing) 'On' manually if you don't like the default appearance.
                CAUTION: This is an undocumented hack that isn't habitually tested by our QA team– though it may give you the 'look' you're after, it may cause unexpected issues elsewhere in the application.
                1. Choose "Window > Ruby Console" to open the Ruby Console
                2. type the following into the console:
                  Test.set_AA_method(4)
                ...and hit Return.
                3. The console should echo back to you something like:
                ...indicating the previous anti-aliasing setting was "0x"
                1. Quit SketchUp and restart. All SketchUp windows will now have 4x anti-aliasing enabled.
                Hope this helps- and remember: this isn't guranteed to work on all Macintosh models.
                john
                By: Kristoff Rand
                  driven
                  tells you what it's set at...
                  Test.get_AA_method
                  will set it to 4 [ choices 0,1,2,3,4 ]
                  v2013 sets it at 4
                  v2014 sets it at 0, due to some performance issues on some machines, I believe...
                  sorry I'm not TIG or TT
                  john
                    ...but you'll definitely do.
                    Thanks it was wrecking my head but....
                    Test.get_AA_method
                    Error; #<NoMethodError; undefined method `get_AA_method' for Test;Module>
                    <main>;in `<main>'
                    -e;1;in `eval'
                    nil
                      matt.gordon320
                      Test.get_AA_method
                      > <main>;in `<main>'
                      > -e;1;in `eval'
                      > nil
                      I'm getting the same error message 😞
                        driven
                        @rich
                        maybe it's a mac thing???
                        what does
                        Test.methods.sort.join("\n")
                        return...
                        john
                          matt.gordon320
                          For me, console spit this out:
                          AutoClickTime
                          AutoClickTime=
                          AutoDragDistance
                          AutoDragDistance=
                          CorruptModel
                          FindFile
                          __id__
                          __send__
                          ancestors
                          autoload
                          autoload?
                          class
                          class_eval
                          class_exec
                          class_variable_defined?
                          class_variable_get
                          class_variable_set
                          class_variables
                          clone
                          const_defined?
                          const_get
                          const_missing
                          const_set
                          constants
                          define_singleton_method
                          display
                          dup
                          eat_mem
                          enum_for
                          eql?
                          equal?
                          export_animation
                          extend
                          flip_images_for_origami
                          freeze
                          frozen?
                          hash
                          include?
                          included_modules
                          inspect
                          instance_eval
                          instance_exec
                          instance_method
                          instance_methods
                          instance_of?
                          instance_variable_defined?
                          instance_variable_get
                          instance_variable_set
                          instance_variables
                          is_a?
                          kind_of?
                          method
                          method_defined?
                          methods
                          module_eval
                          module_exec
                          name
                          nil?
                          object_id
                          private_class_method
                          private_constant
                          private_instance_methods
                          private_method_defined?
                          private_methods
                          project_textures_from_photo
                          protected_instance_methods
                          protected_method_defined?
                          protected_methods
                          public_class_method
                          public_constant
                          public_instance_method
                          public_instance_methods
                          public_method
                          public_method_defined?
                          public_methods
                          public_send
                          remove_class_variable
                          remove_instance_variable
                          respond_to?
                          send
                          show_fps
                          singleton_class
                          singleton_methods
                          taint
                          tainted?
                          tap
                          time_display
                          time_pick
                          to_enum
                          to_json
                          to_s
                          trust
                          untaint
                          untrust
                          untrusted?
                          use_sg_off_screen
                          use_sg_on_screen
                            driven
                            so, they are missing on Windows...
                            sorry about that...
                            john
                              matt.gordon320
                              No worries! I appreciate you taking the time to help out!
                              • sketch3d.deS Offline
                                sketch3d.de
                                @matt.gordon320 said:
                                ...and is there any way to get it back?
                                you can remove the whole OGL key of SU v2014 from the Windows registry by executing the attached REG file (see archive).
                                Exit SU before doing this, launching SU then the OGL defaults should be restored.
                                hth,
                                Norbert
                                SU v2014 only
