    OpenGL Driver
    14 Posts 6 Posters 2.8k Views 6 Watching
      There's a ruby snippet somewhere that resets the opengl setting that SU declares on first launch.
      But I can't find it...where's cotty when you need him?
      • cottyC
        cotty
        Im here, but I dont know the snippet 😳
        my SketchUp gallery
          OK....
          then we need TIG or Thomthom to bail us out.
          I know for a fact that there's a snippet for this.
            matt.gordon320
            Thanks for the help guys! I'll keep an eye out for TIG or Thomthom
            • KrisidiousK
              Krisidious
              OpenGL settings on the Mac OS X version of SketchUp are different than on Windows, but you should be able to get something nice to look at on either platform. It looks to me a little like you're not running your display at its native resolution, but I can't be sure. Typically, the Mac OS picks a pretty reasonable setting for you- you may (however) want to try forcing FSAA (Full Screen Anti-Aliasing) 'On' manually if you don't like the default appearance.
              CAUTION: This is an undocumented hack that isn't habitually tested by our QA team– though it may give you the 'look' you're after, it may cause unexpected issues elsewhere in the application.
              1. Choose "Window > Ruby Console" to open the Ruby Console
              2. type the following into the console:
                Test.set_AA_method(4)
              ...and hit Return.
              3. The console should echo back to you something like:
              ...indicating the previous anti-aliasing setting was "0x"
              1. Quit SketchUp and restart. All SketchUp windows will now have 4x anti-aliasing enabled.
              Hope this helps- and remember: this isn't guranteed to work on all Macintosh models.
              By: Kristoff Rand
                driven
                tells you what it's set at...
                Test.get_AA_method
                will set it to 4 [ choices 0,1,2,3,4 ]
                v2013 sets it at 4
                v2014 sets it at 0, due to some performance issues on some machines, I believe...
                sorry I'm not TIG or TT
                  ...but you'll definitely do.
                  Thanks it was wrecking my head but....
                  Test.get_AA_method
                  Error; #<NoMethodError; undefined method `get_AA_method' for Test;Module>
                  <main>;in `<main>'
                  -e;1;in `eval'
                  nil
                    matt.gordon320
                    Test.get_AA_method
                    > <main>;in `<main>'
                    > -e;1;in `eval'
                    > nil
                    I'm getting the same error message 😞
                      driven
                      @rich
                      maybe it's a mac thing???
                      what does
                      Test.methods.sort.join("\n")
                      return...
                        matt.gordon320
                        For me, console spit this out:
                        AutoClickTime
                        AutoClickTime=
                        AutoDragDistance
                        AutoDragDistance=
                        CorruptModel
                        FindFile
                        __id__
                        __send__
                        ancestors
                        autoload
                        autoload?
                        class
                        class_eval
                        class_exec
                        class_variable_defined?
                        class_variable_get
                        class_variable_set
                        class_variables
                        clone
                        const_defined?
                        const_get
                        const_missing
                        const_set
                        constants
                        define_singleton_method
                        display
                        dup
                        eat_mem
                        enum_for
                        eql?
                        equal?
                        export_animation
                        extend
                        flip_images_for_origami
                        freeze
                        frozen?
                        hash
                        include?
                        included_modules
                        inspect
                        instance_eval
                        instance_exec
                        instance_method
                        instance_methods
                        instance_of?
                        instance_variable_defined?
                        instance_variable_get
                        instance_variable_set
                        instance_variables
                        is_a?
                        kind_of?
                        method
                        method_defined?
                        methods
                        module_eval
                        module_exec
                        name
                        nil?
                        object_id
                        private_class_method
                        private_constant
                        private_instance_methods
                        private_method_defined?
                        private_methods
                        project_textures_from_photo
                        protected_instance_methods
                        protected_method_defined?
                        protected_methods
                        public_class_method
                        public_constant
                        public_instance_method
                        public_instance_methods
                        public_method
                        public_method_defined?
                        public_methods
                        public_send
                        remove_class_variable
                        remove_instance_variable
                        respond_to?
                        send
                        show_fps
                        singleton_class
                        singleton_methods
                        taint
                        tainted?
                        tap
                        time_display
                        time_pick
                        to_enum
                        to_json
                        to_s
                        trust
                        untaint
                        untrust
                        untrusted?
                        use_sg_off_screen
                        use_sg_on_screen
                          driven
                          so, they are missing on Windows...
                          sorry about that...
                            matt.gordon320
                            No worries! I appreciate you taking the time to help out!
                            • sketch3d.deS
                              sketch3d.de
                              @matt.gordon320 said:
                              ...and is there any way to get it back?
                              you can remove the whole OGL key of SU v2014 from the Windows registry by executing the attached REG file (see archive).
                              Exit SU before doing this, launching SU then the OGL defaults should be restored.
                              hth,
                              Norbert
                              SU v2014 only
